Remote not programming
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=58014
Printed Date: May 02, 2026 at 6:27 PM
Topic: Remote not programming
Posted By: 93expxlt
Subject: Remote not programming
Date Posted: June 19, 2005 at 2:38 AM
Installing a Predator 4901TW alarm/command start combo into a 1992 Ford Explorer.  I can't seem to program the remote.  I have the installation guide & it says:
- turn key on/off
-press & hold brakes
-press valet button 5 times, siren will chrip 3 times
-release brake pedal
-press lock button on the 5 button remote & siren will chirp once - I can't get it to do this,  the alarm seems to be hooked up correctly, led flashes when the brakes or valet switch is pressed.  It will chirp 3 times & the led will glow constantly but will not chirp to confirm programming,   Can anyone help?
Posted By: swamprat323
Date Posted: June 19, 2005 at 9:51 AM
is your antenna plug in all the way.
Posted By: 93expxlt
Date Posted: June 19, 2005 at 1:44 PM
Yep, checked them (its a 2-way) both a couple of times
