Diode or not Trunk trigger to door triger
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=58059
Printed Date: May 01, 2026 at 11:18 PM
Topic: Diode or not Trunk trigger to door triger
Posted By: bizzz
Subject: Diode or not Trunk trigger to door triger
Date Posted: June 20, 2005 at 7:14 AM
Hi Everyone,
My Clifford Cyber 2 (same as Clifford Polaris 4) does not have a separate trunk trigger input. I'll hook up trunk trigger wire to door trigger input of Cyber 2. Do I need a diode between door trigger and trunk trigger? If yes, which way should the band on diode go to?
By the way, is trunk light switch in 1995 Toyota Camry negative trigger? Does negative trigger mean that when the trunk is open, the switch makes contact to ground (= 0 volt) to turn on trunk light?
Thank you all.
Posted By: thepencil
Date Posted: June 20, 2005 at 12:03 PM
Not require. It will be NEGATIVE.
Reference to which way the diode should face. Read the note here. I am sure you will figure it out when you are done reading it.
TOYOTA, CAMRY, 1995, Trunk/Hatch Pin
Tied in with the door trigger on the wagon models.
Trunk/Hatch Pin RED / white    -   light or sw. in trunk
TOYOTA, CAMRY, 1995, Door Trigger
Remove black plastic air duct covering the top right side of the fuse box to access a 6 pin plug containing the RED / white.
Door Trigger RED / white    -
Be careful whose advice you buy, but be patient with those who supply it.posted_image
