How to AddChannel #2 in Silencer 6918A ?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=58097
Printed Date: May 01, 2026 at 1:09 PM
Topic: How to AddChannel #2 in Silencer 6918A ?
Posted By: mezl
Subject: How to AddChannel #2 in Silencer 6918A ?
Date Posted: June 20, 2005 at 9:40 PM
Hi,
My car has one remote system which install from dealer. It's Silencer 6918A
https://www.magnadyne.com/images/transfaxpdf/6900W.pdf
In the instructions, it says "All the alarm modules require an 5912 for channel #2 operation.
Follow the wiring instructions supplied with 5912."
I thought5912 just a relay which plug into pin 3 and pin 10.
So I use a multi-meter to check the this two ping's Ohm and Volt. But it doesn't work when I press the transmitter blue (*) button.
Does anyone have idea with this module? I want add    Power Trunk Release function in my car. Thanks.
Posted By: mezl
Date Posted: June 20, 2005 at 9:46 PM
Posted By: mezl
Date Posted: June 23, 2005 at 7:29 PM
Finally, I got answer by myself.
It can applie to Silencer 6908, 6908A, 6918, 6918A, 6928.
posted_image
I bought a Auto relay from Radioshock and plug in and it works! Now I can press blue button 3sec then trunk will release. It's good to add more function in my old Silence module.
