Door Trigger Wire on 2001 F150
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=58259
Printed Date: May 02, 2026 at 5:12 PM
Topic: Door Trigger Wire on 2001 F150
Posted By: haywireauto
Subject: Door Trigger Wire on 2001 F150
Date Posted: June 23, 2005 at 1:33 PM
Hello, Folks,
I'm in the process of installing an Audiovox Pursuit Pro 9232S upgrade in my 2001 Ford F150 truck with keyless entry.
I'm confused about the Door Trigger connection. I have pulled up a few different wiring guides for my vehicle, and I'm getting differing info. One of the wiring guides says that the door trigger is the BLACK/ lt. blue wire, found in the passenger kick panel. Another says that the BLACK/ lt.blue is the dome supervision, and that the door trigger is BLACK / YELLOW on the left side or BLACK/ pink on the right side.
Can someone set me straight?
Thanks in advance for all replies and information.
Cheers!
Ken in SSF CA
Posted By: mo12v
Date Posted: June 23, 2005 at 2:57 PM
Dome LightBLACK/ BLUE (+) for Dome Light Supervision or (+) InputPASSENGERS KICK PANEL *
* Dome Light:(-) Pin Wire Drivers BLACK / YELLOW All Others BLACK/ PINK Located In A 26 Pin Plug At The G.E.M. Above The Fuse Box.
The BLACK / YELLOW ( - ) catches the drivers door and the BLACK/ pink ( - ) catches the passengers door. The wires are found in their respective door harnesses. Use all wires and diode isolate each.  Both wires may also be found at the GEM module located above the fuse box. On models without a dome light delay use ORANGE / lt. green (-) at the light switch
MO
