05 Accord actuator placement?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=58293
Printed Date: May 03, 2026 at 8:13 AM
Topic: 05 Accord actuator placement?
Posted By: shesaidshewas18
Subject: 05 Accord actuator placement?
Date Posted: June 24, 2005 at 3:19 AM
Anyone know where the actuators should be mounted? Im stuck...
Posted By: us_test
Date Posted: June 24, 2005 at 3:38 PM
There is an opening in the door panel which you would see the glass windo through in most cars.
Use the metal strap to connect it the actuator to the inside of the door frame.
Check autotloc website they have a great video with step by step install (https://www.thehoffmangroup.com/files/quicktime/DoorLock_web.mov)
(1) Kenwood Excelon Head Unit KDC-X589 (24 bit Burr Brown DAC, 3 X 4 volt RCA).
(1) RF Punch 250A2 - running the components.
(1) Hifonics 6.5" Atlas Components (18db crossovers).
