Nitro alarm
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=58305
Printed Date: May 03, 2026 at 11:00 AM
Topic: Nitro alarm
Posted By: nyto
Subject: Nitro alarm
Date Posted: June 24, 2005 at 2:38 PM
hey i have a question...........the nitro alarm 2 way has 6 wires for locking and i have a problem conecting  do i need a realeys how they work i have a 91 ford explorer if i need a realey wish cables do i connect to the realey please help me thanks
Posted By: nyto
Date Posted: June 24, 2005 at 3:56 PM
posted_image
Posted By: mo12v
Date Posted: June 24, 2005 at 5:27 PM
Depending on your vehicle...........You may need to hook it up 5 wire Reversal or Negative Pulse
Either way your Alarm is able to accommodate either one
Power LockPINK / YELLOWDRIVER KICK
Power UnlockPINK/LIGHT GREENPANEL **
** With OEM Keyless Entry ...... Negative Pulse Door Locks
 Without OEM Keyless Entry ....Reversal Rest At Ground Power Door Locks
It Is Common For Lock & Unlock Wire Colors To Reverse.
MO
