2003 Dodge Ram, remote start
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=58313
Printed Date: May 03, 2026 at 3:49 PM
Topic: 2003 Dodge Ram, remote start
Posted By: woodman
Subject: 2003 Dodge Ram, remote start
Date Posted: June 24, 2005 at 1:08 AM
Hello, I have a 507T I want to install, do I need to diode isolate a wire and which one, and what should the diode look or be like. 2003 ram cummings
Posted By: woodman
Date Posted: June 24, 2005 at 5:11 PM
2003 Dodge Ram 4x4. Is there one wire on the ingnition harness for 2003 ram that powers everything on remote start. I have 1 acc wire to the a/c swich and the spare acc to the blower wire. The blower wire to alarm does get a little warm. Is this normal. There should be 1 wire to power up on remote start correct.
Posted By: mo12v
Date Posted: June 24, 2005 at 5:17 PM
I have found some of these trucks need a 40 AMP Relay on the Blower. Have found Relays overheat if using RS with onboard Relays | Constant 12 volts | PINK/BLACK RED / WHTITE | IGNITION SWITCH HARNESS | | Ignition 12 volts | BLUE 16 gauge | IGNITION SWITCH HARNESS * | | Starter | YELLOW | IGNITION SWITCH HARNESS | | Dome Light | BROWN (-) | DRIVER A PILLAR (TECH NOTE) | | Trunk Pin Switch | | | | Parking Lamp | BLACK / YELLOW (+) | AT RELAY BOX UNDER HOOD ** | | Power Lock | WHITE/ DARK GREEN | 14 PIN CONNECTOR IN DRIVER #217 | | Power Unlock | SINGLE WIRE SYSTEM | KICK PANEL *** |
* USE THE SMALL GAGE BLUE WIRE! ** BLACK / YELLOW (+) At Relay Box Under Hood Or At Parking Light. *** WHITE/ DARK GRN Wire Must See Ground Through 820 Ohm Resistor For Lock And Ground Through 330 Ohm Resistor For Unlock.Alt: 220 Ohms. Confermed By More Than One Source The 220 Ohm Worked On Unlock. Single Wire Resistor Door Lock Circuit | Accessories | | Window Up | D\ LT BLU P\ BRN/WHT D\ BLU/WHT P\ GRY/WHT @ DRIVER DOOR MODULE | | | Window Down | F/ WHITE F/ VLT/WHT R/ RED / BLK R/ GRN/WHT | | | Ign Key Warn | BLACK/ DK GRN (-) | IGNITION HARNESS | | Trunk Release | | | | OEM Horn | BLACK/ RED (-) | STEERING COLUMN HARNESS | | Headlights | PURPLE / YELLOW (-) | SEE TECH NOTES | | OEM Alarm Arm | LT GRN/ORANGE | DRIVER KICK PANEL * | | OEM Alarm Disarm | SINGLE WIRE SYSTEM | |
*LT GRN/ORANGE-Arm/Disarm Must See A Ground Pulse thru a 1.5K Ohm Resistor To Arm/Lock and a Ground Thru A 550 Ohm Resistor To Disarm/Unlock Use Double Pulse Unlock. (Installer has Reported 249 Ohm Resistor For Disarm) Reversal Rest At Positive Power Window Circuit | Remote Start | | Tach Signal | TAN/RED | IGNITION COIL | | Ignition #2 | RED / WHITE 16ga* | IGNITION SWITCH HARNESS(TRANS CON) | | Ignition #3 | DARK GREEN | IGNITION SWITCH HARNESS (BLOWER)** | | Accessory | BLACK/ WHITE | IGNITION SWITCH HARNESS | | Neutral Safety | | | | Brake Light | WHITE/ TAN | AT SWITCH ABOVE PEDAL | | Reverse Light | VIOLET/BLACK (+) | 64 PIN CONNECTOR UNDER HOOD*** | | Rear Window Defrost | | |
* Also Has Been Noted As RED. **Ignition # 4 : ORANGE Ignition Switch Harness Air Bag Control Module. *** 64 Pin Connector Located On Firewall By Driver Fender VLT/BLK pin # B7 Transponder By Pass Circuit ......... If Key is GREY-Vehicle has Transponder, If Key is Black-Vehicle Does Not Have Transponder ------------- MO
Posted By: woodman
Date Posted: June 24, 2005 at 5:33 PM
Hi, It looks like I have the wireing correct then. There is no 1 wire that powers up everything correct. I just assume when you turn the key that one wire powers up dashboard. If I had to use a relay for blower how do I wire up. Thank you
Posted By: mo12v
Date Posted: June 24, 2005 at 5:52 PM
SPDT Relay: PIN 87 = Fused 12 Volt Constant or PINK/Black PIN 30 = Blower wire or D/GREEN wire PIN 86 = 12 Volt Constant PIN 85 = Ground while running You could also use your 2nd or 3rd Ignition wire like this: SPDT Relay 2nd or 3rd Ignition wire from RS to PIN 86 PIN 87 = Fused 12 Volt Constant or PINK/Black PIN 30 = Blower Wire or D/Green wire PIN 85 = Ground ------------- MO
Posted By: OhioMike1101
Date Posted: June 24, 2005 at 7:44 PM
i thought the 507t was the digital tilt sensor? Am I dumb?
Posted By: woodman
Date Posted: June 24, 2005 at 8:35 PM
Posted By: mo12v
Date Posted: June 24, 2005 at 8:54 PM
NAH.........No dumbness ............I just started from the second post...........Who knows, could be off brand   ------------- MO
Posted By: woodman
Date Posted: June 24, 2005 at 9:14 PM
I read that the 507T Tilt/Motion sensor can go ff for no reason if it does have a diode on a wire
Posted By: tug747
Date Posted: July 09, 2005 at 10:13 PM
Hey everybody,
I just installed an alarm/remote start in a 2003 dodge ram 1500. everything is working but the check engine light is on, I had to unplug the shift interlock so I could put the truck in gear. has anyone had these issues?
Posted By: tug747
Date Posted: July 10, 2005 at 10:17 AM
ok all problems solved by reading what everyone else has done. everything works. thanks anyway
Posted By: tug747
Date Posted: July 12, 2005 at 9:08 PM
success!!! its in and its works perfect, thanks to all entries on this site.
2003 dodge ram quad cab remote start
Posted By: tug747
Date Posted: July 16, 2005 at 8:49 PM
ok, I'm back for some more help. After installing my alarm/remote start, I have decided to install a power window module. I would like to be able to use the negative trunk output and the negative 3rd channel output on the remote start to roll the windows up and down. the window module has 2 wires, which are both negative inputs, to roll the windows up and down. I'm thinking that if I connect the wires this way everything will work just fine, but from past experience that doesn't always happen. please offer any insite on this issue. also, on the remote start, if a DMM is connected to the "negative output" on the remote start what should the reading be when the signal is sent from the transmitter???
