compustar with 530t window module
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=58340
Printed Date: May 04, 2026 at 9:28 AM
Topic: compustar with 530t window module
Posted By: crucian4
Subject: compustar with 530t window module
Date Posted: June 25, 2005 at 8:17 AM
I recently installed a compustar alarm with CM3000 brain along with 530t wondow module. when I tried to roll up the windows by arming the system. the windows wont go up. It only goes up when I turn of the ignition. What I dont understand is if the violet wire is a "ground when armed" wire, why does it become a ground as soon as the ignition is turned off? I removed the relay for the strater kill/ antigrind, and the violet wire remains grounded even with the alram unarmed. Im totally confused. I read somewhere on here about hooking up a diode but still doesnt make any sense if the ground is oming straight from the CM3000 brain. Thanks for any help!
Posted By: Powermyster
Date Posted: June 25, 2005 at 8:25 AM
can't offer any help with compustar. but most of the systems i've done are an orannge(groung when armed)
was there an arange wire in the harness if so myabe test that wire
can't offer any help with compustar. but most of the systems i've done are an orange(groung when armed)
Posted By: crucian4
Date Posted: June 25, 2005 at 9:08 AM
Sorry if I didnt make it clear. Ok, the "ground when armed" wire on the computer is violet. I took the orange wire of the 530T and tied it in with the "ground when ared" wire (violet of the compustar. The problem is, as soon as I turn the ignition off, the windows roll up because the 530T is recieving a ground signal from the compustar even though the compustar is not armed. Also, when I arm the system, the windows wont go up.
Posted By: hawn13
Date Posted: June 25, 2005 at 8:22 PM
I've had this problem with compustars before the easiest solution is get a pulse time relay and wire to lock wire
Posted By: sbessel
Date Posted: June 30, 2005 at 3:07 PM
I was able to solve this by putting a diode in line with the violet wire, it was getting a ground back from the relay coil, thus closing the windows.
