92 Ford Mustang door locks
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=58388
Printed Date: May 04, 2026 at 10:20 PM
Topic: 92 Ford Mustang door locks
Posted By: IIrjII
Subject: 92 Ford Mustang door locks
Date Posted: June 26, 2005 at 1:38 PM
Hi.  I am doing an alarm on a 92 Mustang with power door locks.  The only thing I am having trouble with is the power door locks.  I did a five wire with a 451m and it didn't work.  I tried several other ways and still couldn't get it to work.  The relay clicks, but there is nothing that happens with the doors.  Can anyone help me?
Posted By: mo12v
Date Posted: June 26, 2005 at 2:24 PM
Did the Door Switch work after you cut the wires & hooked them to the 451m?
Make sure you have cut the right wires and the Door Switch wire & Lock wires are not reversed.
Power Lock pink / YELLOW  5wi either kick panel
Power Unlock pink/green  5wi either kick panel
MO
Posted By: IIrjII
Date Posted: June 26, 2005 at 6:26 PM
yes....had full functionality at the door switch when the 451m was connected, no functionality when it was not...........tryed another 451m just incase and still had the same problem.
is there another way other than a common 5 wire for power lock and unlock in the older fords?
