1st Alarm Install Compustar in Cavalier
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=58398
Printed Date: May 05, 2026 at 4:17 AM
Topic: 1st Alarm Install Compustar in Cavalier
Posted By: ryan2004
Subject: 1st Alarm Install Compustar in Cavalier
Date Posted: June 26, 2005 at 4:59 PM
Hi guys Im new here and hopefully you can help me along the way with questions and any problems I run into.  I bought a Compustar 2WSS-AS alarm and will be installing it inot a 2004 Chevy Cavalier LS Sport Coupe which has an OEM alarm and keyless entry.  I would have a local shop do it but they want $400 for the install.
This will be my first alarm install.  My knowledge of wiring is installing HU's and I did uninstall my basic Python alarm out of my old 97 Cavlier. No power locks or anything. Im a DIY . 1)saves alot of money 2)learn alot 3)you know things are done right and secure.  But alarms are new to me so I want to make sure im doing things right no matter how long it takes me.  I've been doing alot of searching to see what I can find and learn.
I will not be hooking up the remote starter for the car because I really dont need it and I dont want to hassle with it.  So for now I'll leave it be.  Now on to my questions.  Is there any special bypass I will need (remember not installing remote start)?  I heard i might need one for my power locks or something? Also will I need any relays?  If I need any of these things can you point me to which model I will need.
Thanks Ryans
12"Adire Brahma, JBL 1200.1, Knukonceptz wiring,CDT components
Posted By: mo12v
Date Posted: June 26, 2005 at 5:28 PM
Posted By: ryan2004
Date Posted: June 27, 2005 at 10:09 PM
Thanks that list should help.  My car does have keyless entry so it looks like the only special thing i need to do when hooking up my alarm is to diode isolate the - door trigger for both driver and passenger door.  When i hook the diodes up should i wrap it up in electrical tape so no bare metal is showing?  Also is there anything else i might of missed that i need to do?  Thanks again.
Posted By: 2000civic
Date Posted: June 28, 2005 at 4:04 PM
I installed the same compustar alarm on my 2000 Honda Civic and I was told that I had to hook up the remote start for the system to work correctly.  I have not had any problems except that the antenna I was sold was faulty and only worked in weather below 40%. But I sent it back and got a new antenna and it works great.  It really is not that much work to hook the remote start since you need to feed the siren wires and hood senser wire through to the engine comparment anyway.  While you are doing that you just need to feed through the tack wire at the same time.  Good Luck!
Posted By: ryan2004
Date Posted: June 28, 2005 at 9:40 PM
Ok i finally got my alarm today and i've been matching up my wiring connections from my alarm to car wiring.  First off what does BCM stand for?
Now i have some wires that i have no idea to what wire to connect them to in my car.
yellow/black wire on the main wiring harness thats coming out of the starter kill relay?
black wire from - status output
WHITE/ black wire from - 2nd accessory output
violet/black - trunk trigger input aka trunk sensing(connect to - trunck/hatch pin or - trunck/hatch release?)
RED / white -door trigger input
red + door trigger input (not use this one?)
violet/white - trunk ouput aka trunk unlock
ORANGE / black -2nd pulse unlock aka 2nd unlock output (says use this wire and isolate drivers door actuator from rest of doors.  how do i do this and where is the actuator? is it the door trigger thing using the diodes?)
blue - unlock output (+power unlock or 5wi unlock motor?)
blue/black - lock output (+ power lock or 5wi lock motor?)
orange -rearm output
ORANGE / white -disarm output
violet -dome light output (says automatic transmission only. dome light is turned on for 1min after unlock.  I have a manual does that mean dont hook it up?)
Aux 1 and Aux 2 (do i just leave alone)
All these wires I dont know what to hook up to if i even need to hook up some of them.  So can you guys help me out and let me know what i should hook them up to thanks.  I really appreciate all the help.
Posted By: mo12v
Date Posted: June 28, 2005 at 10:12 PM
Not totally familiar with the Compustar 2WSS-AS, but some of the info you have should go like this:
BCM = Body Control Module
VIOLET / Black =
Trunk Pin SwitchBLACK (+)AT LIGHT IN TRUNK
RED / White =  ( Diode Isolate )
Dome LightDR- LT GREEN/ BLACK (-)PASS & REAR- LT BLUE (-) AT BCM *
RED = XXXX
VIOLET / White = ( Relay needed to convert to 12 volts Positive )
Trunk ReleaseBLACK/ WHITEAT MODULE IN LEFT SIDE OF TRUNK
ORANGE / Black =  ( Relay needed to convert to convert Driver Unlock wire )
Drv Door UnlockTANDRIVER KICK PANEL
BLUE & BLUE / Black = ( Reversal Rest At Ground Door Locks )
Power LockLIGHT BLUEPASSENGER
Power UnlockWHITEKICK PANEL
ORANGE = XXXX
ORANGE / White = XXXX
VIOLET = ??? Not sure what Manual Trans has to do with it either )
MO
Posted By: ryan2004
Date Posted: June 30, 2005 at 3:26 PM
Door Trigger i need to use both wires lt GREEN/ black and lt. blue and diode isolate each. The wire should also be  (-) when door is open.
Trunk input wire should be (-) when open if 12v+ when closed use diode
Horn trigger should sound when key in off position if not need relay
Here are the connections i have so far from alarm to car Can you check to see if they're right.
Alarm Car
12v Constant 12volts red +
Starter Starter yellow +
- Ignition Ouput Ignition pink +
Accessory Accessory orange +
Parking Light Parking Lights + brown +
-Trunk Unlock Trunk/Hatch Release BLACK/ white -
Engine Sensing Tachometer white or orange Vac
+Brake Sensing Brake Wire white +
-EBrake Sensing Parking Brake lt.blue -
-Horn Horn Trigger black -
-Light Output use relay if output is 30-60sec. long
-Ignition Output Dont Use
-Starter Ouput Dont Use
-Hood Sensing Dont Use
-Glow Plug and +Glow Plug Dont USe
+Door Sensing Dont Use
+Siren + wire on siren
-Rearm Dont Use
-Disarm Dont Use
Thanks alot i really appreciate it
Posted By: ryan2004
Date Posted: July 09, 2005 at 7:15 PM
mo12v] wrote:
P>Be sure to follow instructions for Lock / UNLock
if your vehicle does NOT have Factory Keyless Entry it will require 2 SPDT Relays and wire as 5 Wire Reversal.
Otherwise it is ( + ) pulse
I have everything working right but i have a few questions on the door lock.  As quted abobe I DO have factory keyless entry.  So all i need to to is hook the [power lock lt.blue, to blue + lock output and power unlock white, to blue/black -lock output]?  Blue doubles as a -unlock output and blue/black doubles as a +unlock output (info. from wiring installation manual).
Also I have a question on the ORANGE / black (drivers door proirity unlock) wire from the alarm.  Do i convert the polarity with a relay?  If so which way - to + or + to -.  Also does this wire connect to the my Unlock motor (tan) from my car?   Thanks
Posted By: ryan2004
Date Posted: July 10, 2005 at 8:50 PM
I have everything working right but i have a few questions on the door lock.  As qouted above I DO have factory keyless entry.  So all i need to to is hook the [power lock lt.blue(car wire), to blue + lock output (alarm wire)and power unlock white(car wire), to blue/black -lock output (alarm wire)?  Blue doubles as a -unlock output and blue/black doubles as a +unlock output (info. from wiring installation manual).
Posted By: Velocity Motors
Date Posted: July 10, 2005 at 11:17 PM
The (-) trigger wire on the Compustar requires the use of relays for Type A and Type C systems.
Posted By: ryan2004
Date Posted: July 11, 2005 at 11:44 AM
Hi, could you be more specific please?  On the alarm it doesnt just say (-) trigger wire.  I have my (-) door trigger diode isolated to the driver side door trigger and passenger side door trigger if thats what your talking about.  Also when you say it requires relays can you point me to the right diagram to use or the name of how the relays are set up so i can find it.  Also can somebody show me what a Posive Pulse Door Lock Diagram looks like?  I have been searching on this site and yahoo with no luck.  Thanks for all the help so far.
Posted By: thepencil
Date Posted: July 12, 2005 at 11:35 PM
diagram
Be careful whose advice you buy, but be patient with those who supply it.posted_image
Date Posted: July 13, 2005 at 1:45 AM
Posted By: ryan2004
Date Posted: July 15, 2005 at 6:38 PM
I hooked my door locks up on my alarm today so i can have factory keyless entry.  I had to wire it as Reversal rest at ground.  I had it working earlier.  But i had to hide my wires and cut them to size.  When I hooked things back up to the relay i think i might of hooked it up wrong so i redid everythign.  Well now only the unlock works with my alarm and not the lock.  I've doubled checked all the wiring and put in new relays.  It works fine when i use my remote for the factory keyless entry.  Could i of fried my lock output on my alarm?
Posted By: ryan2004
Date Posted: July 15, 2005 at 9:36 PM
I just went out side to see what the wires were reading on the relay.  On the lock relay  87,86, and 85 show 12 volts and when i hit lock 85 jumps up a little in volts from 11....V to 12...V.  On the unlock relay 87,86, and 85 show 12v.  When i hit unlock 86 goes from 12v to 0 then back up.
Posted By: ryan2004
Date Posted: July 16, 2005 at 9:08 PM
Its fried cuz the unlock gets 12v when i get the unlock button and the lock does nothing.  Is there another wire i can use for the lock?  Also if i diode isolate the unlock and lock will that prevent the output from frying out?  Which direction do i put the diode in?
Thanks guys
