98 audi a4 doorlocks
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=58469
Printed Date: May 06, 2026 at 7:38 AM
Topic: 98 audi a4 doorlocks
Posted By: marcopolo
Subject: 98 audi a4 doorlocks
Date Posted: June 27, 2005 at 9:13 PM
I installed a viper 791xv everything works but  i only can unlock the car i can lock it i suspect im working in the wrong  lock wire any ideas what im doing wrong
Posted By: mo12v
Date Posted: June 27, 2005 at 10:23 PM
Can you ground either wire and do they work then?
You may need stronger ground for Lock / Unlock which would require 2 SPDT Relays
Try:
Power Lock brn/gry or RED / brn   -  drivers kick or alarm  posted_image
Power Unlock gray/white   -  drivers kick or alarm  posted_image
MO
Posted By: minihif44
Date Posted: July 01, 2005 at 12:55 PM
is it a vac system if it is then u have to cut the blue green wire in the drivers kick panel and wire it for a vac system
