Remote Start, '03 Escalade EXT
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=58515
Printed Date: May 05, 2026 at 4:17 PM
Topic: Remote Start, '03 Escalade EXT
Posted By: Ren92
Subject: Remote Start, '03 Escalade EXT
Date Posted: June 28, 2005 at 4:42 PM
I am using the GMDL-BP and it starts and runs for about 10-15 sec. and then shuts off and does it again.Anyone have any ideals.
Posted By: mo12v
Date Posted: June 28, 2005 at 9:07 PM
Be sure you have the GMDL-BP programmed and that the GMDL-BP is powered up during and after cranking
MO
Posted By: OhioMike1101
Date Posted: June 28, 2005 at 10:27 PM
double check that you have both IGN and ACC wires powered.  Also make sure the GMBP is programmed correctly.
IBPLXR is a much better bypass.....  I hate the GMBP after using the PLXR.
Posted By: Ren92
Date Posted: June 28, 2005 at 11:04 PM
I powered up the second ign.(big white) but I only power up the orange acc. Is there another acc. wire I need to power up?
Posted By: KarTuneMan
Date Posted: June 29, 2005 at 12:55 AM
BROWN......
Posted By: Ren92
Date Posted: June 29, 2005 at 9:05 AM
Are you saying power the brown as an acc.?
Posted By: Ren92
Date Posted: June 29, 2005 at 10:24 PM
Ok I have both ign. and acc. wires hooked up and the truck  still wont stay running.It runs for about 8-10sec. I figured I would try a 555l also with no change so I am think it's not the passlock system.What else could it be?I need to get this truck out of our bay but don't want it to leave with out it working. I am new to the Viper alarms so is there something I might not have hooked up that would turn the relay pack off?
