Audiovox ground when running wire?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=58554
Printed Date: May 05, 2026 at 10:47 AM
Topic: Audiovox ground when running wire?
Posted By: xerox
Subject: Audiovox ground when running wire?
Date Posted: June 29, 2005 at 9:09 AM
Hooking up a bypass kit to an audiovox aps-996a alarm/remote start and the gm-u.7 wants a "ground when running" - input on its blue wire. I have looked high and low for the source of this on my alarm and cannot find it...any suggestions?
Posted By: Powermyster
Date Posted: June 29, 2005 at 9:55 AM
some alarm aux's can be programmed to come on when disarming.
dunno bout when running but see if the aux's are programmable like this
Posted By: metaverse
Date Posted: June 29, 2005 at 9:03 PM
On the 996a there should be a Light blue Ignition 3 output.
It should provide a "300ma ground output 3 seconds before remote start, ground while running, and 4 seconds after the remote start turns off/shut down"
Use this wire. Should work fine with no programming required..
Posted By: xerox
Date Posted: June 29, 2005 at 10:45 PM
perfect, thanks guys!
