nissan sentra drivers priority unlcok
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=58675
Printed Date: April 19, 2026 at 4:21 AM
Topic: nissan sentra drivers priority unlcok
Posted By: jnye6625
Subject: nissan sentra drivers priority unlcok
Date Posted: July 01, 2005 at 10:24 AM
I have a 2002 nissan sentra ser spec v with factory keyless entry.  The keypad has drivers priority unlock, then you hit it again and it unlocks all doors.  I know the compustar alarm allows me to keep this feature, but what wires on the car do i connect to for this to work.  Would there be one for lock, unlock drivers, and unlock passenger?  Also will i need to setup relays like i did on my old truck, or are there already relays in the car because it came with keyless entry from the factory?  Thanks
Posted By: chriswallace187
Date Posted: July 01, 2005 at 12:43 PM
On most Nissans I've seen they have a doorlock/keyless entry control module with the driver's unlock relay built in. In order to do priority unlock with your alarm, you'll need to find the lock and unlock wires on the car (I'm assuming that they are both negative), as well as the driver's unlock motor lead. Hook up the wires as follows:
(-) lock output from alarm - lock wire on car
(-) 2nd unlock output from alarm - unlock wire on car
(-) unlock output from alarm - terminal 85 on a relay
terminals 86, 87 on relay - fused 12v+ constant
terminal 87a - switch side of driver's unlock motor lead
terminal 30 - motor side of driver's unlock motor lead
C Renner's Auto Electronix
Posted By: jnye6625
Date Posted: July 01, 2005 at 2:19 PM
So there is no way of utilizing my existing relay to do driver's door priority?  It would be nice to be able to do this rather than tear into my door also.  Thanks
Date Posted: July 01, 2005 at 6:12 PM
you shouldn't have to tear into the door...the motor lead most likely goes through the door boot - you can also try to listen for a relay clicking when the driver's unlock is pressed...but usually the relay is built into the keyless entry module.
