Integra Wire location
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=5874
Printed Date: April 30, 2026 at 11:12 PM
Topic: Integra Wire location
Posted By: acura96
Subject: Integra Wire location
Date Posted: November 25, 2002 at 3:55 PM
I've read many messages in this forum about the wire location of the the Integra but I still don't know what and where are the "Driver Kick Pannel, Distrib or tach test conn". Can anyone give me more detail of these locations?  Any help would be greatly appreciated.
Posted By: joelr7309
Date Posted: November 25, 2002 at 10:50 PM
Well, Driver's kick panel say it all,  it's the driver kick side right by the fuse box and all the wire are there,  like door trigger and parking light's and ect, tons of wires there,  steering columm is where the key goes in and follow all those wires and it all so goes to the drivers kick panel, starter, ignition, and accesory,  and TACH is at the engine, where all your spark plug wire connect  to the distributor,  there are two wire you'll see clearly one is blue and I think the the second one is white, blue is the TACH wire, use your digital meter 12 ACV.  Follow the wires and it should follow up to the firewall, then inside the car,  not sure where it is inside the driver's kickpanel,  USE YOUR DMM METER TO READ VOLTAGE OR YOU END UP BURN THINGS.
THE ROOKIE!~
