Avital 3200 aux output
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=59309
Printed Date: March 30, 2026 at 4:39 AM
Topic: Avital 3200 aux output
Posted By: lostreception
Subject: Avital 3200 aux output
Date Posted: July 12, 2005 at 6:29 PM
My Avital 3200 has an aux output on the trunk rls/ aux out line i was wondering how i can wire up  a relay to turn on some accesories i have. its a negative pulse according to the manual
Date Posted: September 08, 2005 at 9:38 PM
anyone
Date Posted: September 08, 2005 at 9:39 PM
anyone
Posted By: kgerry
Date Posted: September 09, 2005 at 2:45 PM
actually the validity on this channel is selectable... you just use it as a negative to turn on a relay (the postive side of the coil already having power).... just wire it the same as if you were doing trunk release.... if you want it latched vs. momentary just change the validity setting in the programming menu....
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
Posted By: blazeronspokes
Date Posted: September 09, 2005 at 5:06 PM
you wire it like this:
85: - output from alarm brain(whire/blue, or RED / white)
86: + constant power source
87: + constant power source
30: to trunk release wire
