2005 toyota corolla autostart tach wire
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=59739
Printed Date: May 14, 2026 at 10:00 PM
Topic: 2005 toyota corolla autostart tach wire
Posted By: superman1218
Subject: 2005 toyota corolla autostart tach wire
Date Posted: July 19, 2005 at 9:02 PM
ok guys, I used the far right connector on the ECM behind the glove box and it says to use the number 5 pin.. That would make it ot be a brown wire..I programmed the alarm to th on tach reading and I still can't get tach reading..Alarm is not a problem..(Hornet with autostart)I have done Hundreds of auto starts but for some crazzzyy reason this new 2005 corolla is a piece of work..any one got some suggestions on were to look..for a tach reading???
------------- superman
Posted By: swamprat323
Date Posted: July 19, 2005 at 9:22 PM
pin shoudl should be a "black" wire. if no luck go to the coil.
Date Posted: July 19, 2005 at 9:52 PM
where is the coil on that car.. Could not find it.. look for hours.. and yes, I imagined a black wire also..90% of the time its a black wire for tach..
Date Posted: July 19, 2005 at 10:37 PM
that 2005 corolla has a coil assembly with with 4 connectors that go on top of the spark plugs..thats all I know abuot the coil
