Alarm to aftermarket actuator relay
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=60207
Printed Date: May 12, 2026 at 4:17 AM
Topic: Alarm to aftermarket actuator relay
Posted By: Alpine Guy
Subject: Alarm to aftermarket actuator relay
Date Posted: July 27, 2005 at 5:55 PM
I just installed 4 door lock actuators and a starter/alarm system in a 2002 Dodge Neon, my only problem is figureing out how to wire up the relays to make them work. I have all the actuator wires leading together in the end and tested them by touching one to ground and one to 12v and they work properly. Just how would i do a relay set up so it will switch one wire to ground while the other is positive, then the complete opposite to make the actuator work the other way too. The alarm signal output is (-) ------------- 2003 Chevy Avalanche,Eclipse CD7000,Morel Elate 5,Adire Extremis,Alpine PDX-4.150, 15" TC-3000, 2 Alpine PDX-1.1000, 470Amp HO Alt.
Posted By: mo12v
Date Posted: July 27, 2005 at 6:01 PM
2 SPDT Relays Actuators / Reverse Polarity | To lock or unlock the vehicle, polarity is changed on one motor leg.  |
------------- MO
Date Posted: July 27, 2005 at 10:14 PM
I tryed that but it shorted out as aoon as I connected 12v.
Date Posted: July 28, 2005 at 10:21 AM
i got them from canadian tire, i'll go check them with a meter. ------------- 2003 Chevy Avalanche,Eclipse CD7000,Morel Elate 5,Adire Extremis,Alpine PDX-4.150, 15" TC-3000, 2 Alpine PDX-1.1000, 470Amp HO Alt.
Date Posted: July 28, 2005 at 10:31 AM
Thats what it is, ,so much for saveing $2 ugghh  ------------- 2003 Chevy Avalanche,Eclipse CD7000,Morel Elate 5,Adire Extremis,Alpine PDX-4.150, 15" TC-3000, 2 Alpine PDX-1.1000, 470Amp HO Alt.
Posted By: mo12v
Date Posted: July 28, 2005 at 2:30 PM
2 bucks is worth the knowledge....next time
------------- MO
Date Posted: July 28, 2005 at 7:21 PM
Very true, altho i wish i spent that on a hamburger while i was doing the install....
