’04 Camry Trunk Release
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=60682
Printed Date: April 10, 2026 at 3:04 PM
Topic: ’04 Camry Trunk Release
Posted By: tbo1
Subject: ’04 Camry Trunk Release
Date Posted: August 04, 2005 at 3:08 PM
how do i wire a 5wi conection for trunk release in an '04 Camry. i know the wire and the location according to directwires. any help would be greatly appreciated
tbo
Posted By: profuse007
Date Posted: August 04, 2005 at 3:16 PM
the trnk line must be cut in half and interrupt w/ a 5wire relay.
85- trunk oupt from alarm unit
86- 12volt constant
30- 12v constant
87a- objective wire goin toward the dash
87- objective wire goin toward the trunk popper
Houston,TX
Posted By: tbo1
Date Posted: August 04, 2005 at 4:07 PM
thank you much.
tbo
Posted By: KarTuneMan
Date Posted: August 06, 2005 at 9:53 AM
you need to also trigger the trunk key sence wire with the trunk trigger BEFORE the relay. otherwise the factory security (if it has it) will go off. Its the green and white wire just below the blue/white trunk pop wire. grab on to your trunk pop trigger in front of the relay and diode isolate, cathode facing your alarm.
Posted By: tbo1
Date Posted: August 06, 2005 at 2:28 PM
thank you KarTuneMan. you guys been helpful. much appreciated.
tbo
Posted By: Chris Luongo
Date Posted: August 07, 2005 at 11:59 AM
KarTuneMan's tip is correct.
Factory alarm is standard only on the XLE "luxury" model.
LE, SE, and base don't have the alarm from the factory.
You might encounter a dealer-installed Toyota VIP alarm one some of these; I'm not sure if it will have the key-cylinder-disarm wire though.
