Alarm yellow wire
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=60778
Printed Date: April 09, 2026 at 2:31 PM
Topic: Alarm yellow wire
Posted By: domiyork
Subject: Alarm yellow wire
Date Posted: August 05, 2005 at 4:39 PM
Hi,
When installing an alarm does it matter if the yellow wire from the alarm goes to acc or ignition wire on the car?
will the alarm get confused when the acc wire goes dead during start up?
i have used the ignition wire before
please help.
Posted By: chungo
Date Posted: August 05, 2005 at 5:35 PM
the kill switch might not work if you use the acc wire
Posted By: Teamrf
Date Posted: August 05, 2005 at 5:58 PM
You have to use ignition...acc. doesn't keep power during crank. Therefore the car will still start.
~The Rookie~
Rookie of the year that is...
Don't let the smoke out of your equiptment..it doesn't go back in.
Posted By: slab42
Date Posted: August 05, 2005 at 6:40 PM
If you are using it for starter kill, then yes, you must use ignition, if you are using it for just the ignition input to the alarm, for programming, etc.  you should be able to get away with acc, but I have no idea why you can't just use ign.
