How to trigger remote starter
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=6087
Printed Date: May 08, 2026 at 5:49 PM
Topic: How to trigger remote starter
Posted By: BSC33
Subject: How to trigger remote starter
Date Posted: November 30, 2002 at 10:54 PM
I have a '99 Grand Prix GTP that I had a design tech add-on remote starter installed in (20022). The guy installed it incorrectly, and I need to know which wire to trigger the starter off of. Right now, it is triggering off of a wire that pulses when any button on the keyfob is hit twice. So if I hit any button twice in three seconds, it will start the car. One problem is, when I hit the lock button once while the doors are shut, I get two pulses on this wire, and the car starts. So, I'm assuming he hooked the trigger up to the wrong wire. Which wire should I hook the trigger up to??? I want the car to start when I hit a certain button twice...the lock button, maybe. Also, if you know which wire it is, please tell me where to locate it. Thanks for any help!
Posted By: djfearny2
Date Posted: December 01, 2002 at 12:01 AM
no thats usually right but what you have to do is step up the pulse activation input in programming or for dip switches if this does not work than this alarm is not good for you.
Jon
Installer/Help Technician
---coral springs florida---
