Toyota Factory Keyless Entry w/Ignition
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=6104
Printed Date: May 08, 2026 at 12:57 PM
Topic: Toyota Factory Keyless Entry w/Ignition
Posted By: toddc
Subject: Toyota Factory Keyless Entry w/Ignition
Date Posted: December 01, 2002 at 1:39 PM
I just installed a remote start on my 2003 Toyota Matrix which uses the factory keyless entry to activate starting.  Unfortunately, the factory keyless entry will not operate while the car is running.  Does anyone know a way around this?  The car does not have an OEM alarm, so I'm hoping its just a matter of disconnecting the ignition sense wire to the keyless entry module.  Schematics and module location would be very helpful if anyone has them.  TIA
-Todd
Posted By: finnman925
Date Posted: December 03, 2002 at 4:04 PM
I'll look it up for you tomorrow
Brian
Posted By: mxxmikexx
Date Posted: December 03, 2002 at 5:55 PM
why dont you just interface the remote starter to operate the locks and be done with it?
Posted By: djfearny2
Date Posted: December 03, 2002 at 6:18 PM
yea you can get a dei valet 551r and it has a remote and and keyless entry.
Jon
Installer/Help Technician
---coral springs florida---
Posted By: toddc
Date Posted: December 03, 2002 at 6:57 PM
As I mentioned in my first post, I have a system that relies on use of the factory remotes to start the vehicle.  In retrospect, I should have purchased a unit that does everything.  I think I have found the location of the factory  keyless enty module.   Its located in the passenger side upper rear quarter panel, by the hatch.  My brother works at a Pontiac dealership and was able to pull the location drawing from the Vibe.  He also was able to get a wiring schematic, buts its pretty vague.  It only shows five wires coming out of the module.  Thoughts?
-Todd
Posted By: diabloed
Date Posted: December 03, 2002 at 10:50 PM
12volts
posted_image
 white & black
posted_image
posted_image
 ignition harness
Starter red  +  ignition harness
Second Starter N/A
Ignition BLACK/ white  +  ignition harness
Second Ignition BLACK / YELLOW  +  ignition harness
Third Ignition N/A
Accessory blue/red  +  ignition harness
Second Accessory N/A
Keysense blue/black  -  ignition harness
Power Lock green  -  passenger kick panel  posted_image
Power Unlock blue/black  -  passenger kick panel  posted_image
Lock Motor blue  5wi driver kick, door harness
Unlock Motor red  5wi driver kick, door harness
Parking Lights+ green  +  driver kick panel
Parking Lights- GREEN / WHITE  -  headlight switch
Hazards yellow/black  -  hazard switch
Turn Signal(L) GREEN/ red  -  steering column
Turn Signal(R) GREEN/ orange  -  steering column
Reverse Light RED / black  +  pin 11, conn. 3 @ PCM  posted_image
Door Trigger RED / yellow  -  driver kick panel
Dome Supervision comes on with unlock
Trunk/Hatch Pin common with door trigger
Hood Pin N/A
Trunk/Hatch Release blue/white  -  release switch on dash
Power Sliding Door N/A
Factory Alarm Arm arms with lock
Factory Alarm Disarm disarms with unlock
Disarm No Unlock use key sense
Tachometer black  ac  pin 5, conn. 4 @ PCM  posted_image
Wait to start N/A
Brake Wire GREEN / WHITE  +  brake pedal switch
Parking Brake RED / black  -  parking brake switch
Horn Trigger GREEN/ YELLOW  -  steering column
