viper 791xv lock unlock on ing
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=61221
Printed Date: May 16, 2026 at 2:57 PM
Topic: viper 791xv lock unlock on ing
Posted By: northwestcustom
Subject: viper 791xv lock unlock on ing
Date Posted: August 12, 2005 at 2:47 PM
I am having problems trying to get the lcoks to lock when ignition is turned on, they unlock when the ignition is turned off. I tried to program it and it goes back to normal and says it shoudl do it, but it doesn't. When I arm the truck it locks and when I disarm it, it unlocks. So i have no idea what is the problem. I installed a viper 791xv on my 98 chevy c1500. I installed the automatic power window kit that allows your windows to roll up when you arm it and you can roll them down. I also shaved my doors and use the 4 and 5 channel on the alram to operate them. If anyone can help that woudl just make my day. Thank You
------------- Thank you
Randy Sinclair
Posted By: mo12v
Date Posted: August 12, 2005 at 4:55 PM
U are checking the Ignition Door Locks with the doors closed??
------------- MO
Posted By: kgerry
Date Posted: August 12, 2005 at 6:14 PM
with the Bitwriter in the program menu do you have ign controlled lock ON?
------------- Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
Posted By: auex
Date Posted: August 12, 2005 at 6:42 PM
Why do you care about your locks??? Locks and shaved handles don't mix. Also if you start the vehicle with any trigger open then the doors will not lock with ign.
------------- Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
