Galaxy 3000 2w Remote Issue
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=61304
Printed Date: May 03, 2026 at 10:36 PM
Topic: Galaxy 3000 2w Remote Issue
Posted By: mdcrc
Subject: Galaxy 3000 2w Remote Issue
Date Posted: August 13, 2005 at 10:53 PM
Spent all day installing alarm. Good job if I must say so myself, except the alarm does not acknowledge the remotes. The manual refers to Programing #21 to press button two on your one way remote to setup FM remotes. Only problem is the only remotes that came with unit are both 2 ways. Certainly there has to be another way to fire up the FM remotes?????
------------- Mark
Posted By: mdcrc
Date Posted: August 14, 2005 at 6:54 PM
Problem Solved ------------- Mark
Posted By: ryan_88
Date Posted: August 14, 2005 at 7:11 PM
how did you solve this problem? is there some sort of antena that needs to be wired in for the fm remotes?
Posted By: mdcrc
Date Posted: August 14, 2005 at 9:40 PM
Yes there is a module aprox. 2"x2" that wires to the alarm panel and then it connect to the ribbon that goes to the antena.
------------- Mark
Posted By: ryan_88
Date Posted: August 14, 2005 at 10:37 PM
does this 2"x2" module plug in where the scynet port is? does it have 5 pins on one side, and two 3 pin connectors on the other?
Posted By: mdcrc
Date Posted: August 14, 2005 at 10:42 PM
Correct, It does plug into the Scy Port, then plug into either one of the 3 pins on the FM module. Then of course the ribbon plugs into the FM module on the other end.
------------- Mark
Posted By: ryan_88
Date Posted: August 15, 2005 at 10:03 PM
ok, i see, but then the antenna has two, two pin wires on it too. one is blue and one is red, where do those go?
Posted By: tacalin
Date Posted: August 16, 2005 at 6:20 AM
in the unit: - red = LED -blue = valet
Posted By: ryan_88
Date Posted: August 16, 2005 at 1:37 PM
right, well i already have the LED with its wire pluged in there, and the valet switch with its wire pluged in there too. so thats why i am lost. the antenna has red and blue wires too. they can't all be plugged in, can they?
Posted By: mdcrc
Date Posted: August 16, 2005 at 11:55 PM
Ryan, You have your choice of where you want your Led?Valet to be. On the antenae or remotely. You can use either or one or the other.
------------- Mark
Posted By: ryan_88
Date Posted: August 17, 2005 at 5:32 AM
ok, i see now. so if i dont plug those in on the antenae thats ok too? i think i get it now. thanks for your help mark.
ryan
Posted By: mdcrc
Date Posted: August 18, 2005 at 9:49 PM
No Problem, Let me know what you do with your mutiple sensors.
------------- Mark
