2 questions, fm remote & diodes
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=61308
Printed Date: May 03, 2026 at 8:48 PM
Topic: 2 questions, fm remote & diodes
Posted By: ryan_88
Subject: 2 questions, fm remote & diodes
Date Posted: August 14, 2005 at 12:15 AM
hi, i just finished installing the scytek galaxy 3000 2w-1 in my '97 jeep wrangler. i pluged in the shock sensor, but i'm not sure what to do to install the microwave sensor, and the glass break sensor posted_image. i have one sensor input in the wire harness. do i cut off one end of the plug for the microwave sensor cable and then attach the exterior and interior trigger wires to that then ground it and 12V? then to get the glass break sensor in do i need a diode, or can that be spliced in somewhere else?
now i also have the fm remote. do i just need to program this? or should it have some sort of extra antenna to plug in, and if so, where does this go?
thanks for all your help, this is my first alarm system.
Posted By: KarTuneMan
Date Posted: August 14, 2005 at 1:29 AM
`microwave....and glass breakage (waste of time) overkill. OK !!   Come on man, the alarm only keeps honest people, honest. All that fancy stuff..................well, you know!         Don't spend money to im press your friends.....
Posted By: mdcrc
Date Posted: August 14, 2005 at 4:43 PM
Hey, I just installed the same alarm, and I have the same situation. I figured out my remote problem and now I am going to work on the second sensor. I have seen it using diodes on some webpage. I know that can be done. I am going to hook up the second sensor using the single (Blue) wire on the control. I suspect it will work but probably no warning alarm since you do not have that option.
Mark
Posted By: mdcrc
Date Posted: August 14, 2005 at 4:55 PM
My mistake Blue/Black wire.
Mark
Posted By: ryan_88
Date Posted: August 14, 2005 at 7:10 PM
how did you solve the remote issue? and do you know the web site that you found the diodes at?
Posted By: mdcrc
Date Posted: August 14, 2005 at 7:56 PM
Well I had the ribbon wire pinch going to the Amtena. Seems to be ok now. I have not been able to find the diagram for the diodes, but it should be pretty easy to do. You willl probably require about 6 diodes to do an extra sensor.
Mark
Posted By: ryan_88
Date Posted: August 14, 2005 at 10:26 PM
where exactly did you plug the FM remote antenna in though? im not seeing where that goes.
Posted By: mdcrc
Date Posted: August 15, 2005 at 7:57 PM
The ribbon wire from the antenae plugs into the other end of the FM module. The opposite end that has the 2-3 wire plugs
Mark
Posted By: sharc
Date Posted: August 25, 2005 at 3:13 PM
Hi Guys,
I can help you with the diode problem.  There is usually two modes (dual modes/zones) in a sensor.
One of the lines coming out of the sensor is usually a warning line (zone 1) that causes the alarm just to chirp or give a warning when that zone has been violated.
The other line (zone 2) will trip off the alarm, usually instanttly.  If you have two or more sensors, you will need to diode "OR" the zone lines together.  Diode "OR" means sensor 1 "OR" sensor 2 will trip the associated line going back to the alarm controller.
Typically alarm controllers look for external pull down command (grounding) of the sensor lines to trigger an alarm or warning.  The sensors provide these pull downs to the alarm controller.
If you are using more than one sensor, like a shock sensor and also a microwave sensor, you will need to diode "OR" the lines together back to the controller.
If you are only using one sensor, you dont need the diodes.  If you are using (2) sensors, you will only have to add diodes on the 2nd sensor, but its okay to add diodes on both if you wish.
Obtain (2) 1N4001 diodes (available at Radio Shack).  Connect the first sensor (both lines) directly to the controller.  On the second sensor, if it has only one output to the controller, most likely that is a line that will trip the alarm instantly.  If there are two lines, one will be for a warning line and the other for an instant alarm trip.
From the wire(s) at the end of the 2nd sensor, solder one wire onto the lead of the diode that has the band at one end.  This is the cathode lead of the diode.  When the sensor makes that line goe low, the diode will be forward biased and allow the ground to pass to the alarm controller. The other lead of the diode (anode) will get soldered to the wire of the other sensor that is tied to the alarm controller.  Zone 1's of each sensor are tied together with diodes and Zone 2's of each sensor get tied together.  You want warning lines to be tied with warning lines and instant trip lines tied with other instant trip lines. Dont mix the two or you will have chaos!
I prefer to put shrink wrap over all of my solder connections, but electrical tape is fine too.  When you splice into the existing (1st) sensor line, all you have to do is remove about 1/8" of the insulation and wrap the anode lead coming from the second sensor around the exposed wire and solder it.  Again use shrink wrap or electrical tape over the soldered connection.
You will also need to piggyback (tie together) the power lines of each sensor, typically red to red, black to black.
Okay, so what do the diodes do?  They allow each sensor to trigger the alarm controller but they become isolated from each other.  The controller sees both, but each sensor does not see each other and will have no affect on each other.
If the controller uses pull up commands rather than pull down commands, all you do is turn the diodes around with the band facing the controller rather than the sensor.
Use diodes on each additional sensor added.  Again, the first sensor does not need them.  Use diodes on 2 or more sensors.
I hope this helps.
- Jim
Posted By: mdcrc
Date Posted: August 25, 2005 at 10:33 PM
Thanks Jim
Mark
