2001 mercury cougar remote starter
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=61310
Printed Date: May 03, 2026 at 7:07 PM
Topic: 2001 mercury cougar remote starter
Posted By: mistahiggs
Subject: 2001 mercury cougar remote starter
Date Posted: August 14, 2005 at 12:48 AM
A customer had a Clifford Matrix RS installed in a 2001 mercury cugar about 18 months ago. The customer wanted us to order another remote, so one of my installers checked under the dash to see what the model the remote starter was. Now the remote start function does not work. I reset the brain and have all the correct voltages on the starter and ignition wires during the remote start sequence. I even tried to swap out the 555f module. The keyless entry still works, but when the remote start is activated the car does not start. The AC and lights come on, and the parking lights blink on and off as if the car is running. Can anyone tell me why the car is not starting? thank
higgs
Posted By: iskidoo
Date Posted: August 14, 2005 at 11:22 AM
Are you getting 12 volts on the starter wire during the initial start routine? Did the remote start portion ever work? Is there a starter kill relay and could the 12 volt feed be wired to the key side rather than the motor side of the starter wire relay?
If you start with the key then engage the remote starter does the engine remain running when you turn the key off? If so then it sounds like the starter output is getting where it needs to to engage the starter motor.
Steve G
Posted By: extreme1
Date Posted: August 14, 2005 at 11:45 AM
555s for the cougar, that's probably your new problem
Shaughn Murley
Visions Electronics
Red Deer, Alberta
Posted By: swamprat323
Date Posted: August 14, 2005 at 11:55 AM
have you tried the "shutdown diagnostitcs" to see what that says. pu the key in the igntion then try to RS.
Posted By: iskidoo
Date Posted: August 14, 2005 at 11:57 AM
I don't think the system thinks that it shutdown. If the lights are flashing it thinks that it successfully remote started.
Steve G
Posted By: Chris Luongo
Date Posted: August 14, 2005 at 12:07 PM
Observe the security light in/on the dash. When you start the car with a good key, the light comes on for a moment, then goes out. If the car does not see a good key, the light will flash rapidly----and that means you have a problem with your bypass.
Date Posted: August 14, 2005 at 4:40 PM
As far as I can tell, the brain thinks the car is running.  I have every electrical indication that the system is doing everything it's supposed to, but I have no mechanical functions, no ignition, no starter.   Possible that the brain is fried?  If so, does anyone know what Viper brain I can swap it with?
Posted By: iskidoo
Date Posted: August 14, 2005 at 4:42 PM
Does it have the relay pack or satelitte relays? Or are the high current connections internal in the brain?
Steve G
Date Posted: August 14, 2005 at 8:52 PM
it has the relay pack for the high current connections, then smaller guage ribbon to the brain
Date Posted: August 14, 2005 at 9:14 PM
if you have power to the igntion wires and STARTER wire form the relay pack, when you remote start, then it wont be the alarm.
im just confirming this....you do have power on ALL ign. and acc wires also have power to the STARTER wire.
Date Posted: August 14, 2005 at 9:50 PM
power to both 12v wires, power on the accessory line, and a 12v surge to both the ignition and starter when remote started
Posted By: iskidoo
Date Posted: August 14, 2005 at 9:55 PM
Surge to the ignition? The Ignition should show power and remain on throughout the whole sequence. Is it really surging like the starter wire or is it constant during the remote start cycle?
Steve G
Date Posted: August 14, 2005 at 10:06 PM
yes doulbe check to see if got constant vlots on the igntion wire, if it is surge, check the other igntion wire in the realy pack, in the case its a bad relay use the another igntion wire on the relay pack. when you are checkign the voltage are you doing on wires in the relay pack or the igntion harness. waht kind of connection are you using. if they are T-taps, or other liek that remove them and re do it, with out the T-taps.
Date Posted: August 14, 2005 at 10:17 PM
I'll have to double check the voltage again tomorrow on the ignition, and I am checking the voltages next to the ignition harness. I never use t-taps, only eyelets, wraps and solder. Hopefully it's just a bad realy. Thanks for all the feedback.
Date Posted: August 14, 2005 at 10:27 PM
well if you did not use Taps and have a good connection dotn matter were you take volts at. just narrow it down to something.
