Clifford 3.5, Door Locks, 1996 Nissan 240SX
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=61314
Printed Date: May 03, 2026 at 2:18 PM
Topic: Clifford 3.5, Door Locks, 1996 Nissan 240SX
Posted By: sl4mike
Subject: Clifford 3.5, Door Locks, 1996 Nissan 240SX
Date Posted: August 14, 2005 at 2:23 AM
Hi i have a nissan 240sx and its my first time installling a alarm im just woundering if any of you guys have installed a clifford unit into one of these vehicle before., if so a wiring diagram of the whole door lock stuff would help. or if any of you guys have the 96 nissan 240sx service manual pdf. that would be awsome sl3mike@yahoo.com or hit me up on aim sl4mike Thanx alot
Posted By: mo12v
Date Posted: August 14, 2005 at 8:24 AM
| Constant 12 volts | WHITE | IGNITION SWITCH HARNESS | | Ignition 12 volts | BLACK/ RED | IGNITION SWITCH HARNESS | | Starter | BLACK / YELLOW | IGNITION SWITCH HARNESS | | Dome Light | RED / WHITE (-) | 84 PIN CONN. HIGH IN DR. KICK PANEL * | | Trunk Pin Switch | RED (-) | AT LIGHT IN TRUNK | | Parking Lamp | RED / BLUE (+) | AT HEADLIGHT SWITCH | | Power Lock | L GREEN / WHITE | 21 PIN WHITE PLUG | | Power Unlock | BROWN | IN DRIVER KICK PANEL |
* With Power Door Locks, RED / WHITE (-) Wire Also Located At "Smart Entry Control Unit" Behind Left Side Of Driver Dash Top Right Of Fuse Block. Negative Pulse Door Locks | Accessories | | Window Up | D\ GREEN P\ RED / WHITE @ MAIN SWITCH | | | Window Down | R/ BLUE S/ RED / BLACK | | | Ign Key Warn | BLACK/ PINK (+) | IGNITION SWITCH HARNESS | | Trunk Release | N/A | | | OEM Horn | GREEN / WHITE (-) | STEERING COLUMN HARNESS | | Headlights | RED / YELLOW (DR) & | RED / BLUE (PS) (+) AT HEADLIGHT SW. | | OEM Alarm Arm | L GREEN/ RED (-) | AT "SMART ENTRY CONTROL | | OEM Alarm Disarm | GREEN/ YELLOW (-) | UNIT" BEHIND DRIVER DASH |
Reversal Rest At Ground Power Window Circuit | Remote Start | | Tach Signal | YELLOW/RED | AT ENGINE CONTROL MODULE * | | Ignition #2 | WHITE | IGNITION SWITCH HARNESS | | Ignition #3 | N/A | | | Accessory | WHITE/ BLUE | IGNITION SWITCH HARNESS | | Neutral Safety | NOT GROUNDING TYPE - | OEM SWITCH OPENS STARTER CIRCUIT | | Brake Light | RED / GREEN (+) | AT SWITCH ABOVE BRAKE PEDAL | | Reverse Light | RED (+) | 84 PIN CONN. HIGH IN DR. KICK PANEL | | Rear Window Defrost | BLUE/GREEN (-) | AT REAR WINDOW DEFOGGER SWITCH ** |
* Engine Control Module Located In Passenger Kick Panel. YELLOW/RED Wire Located At Pin #3. ** With Power Door Locks Only: BLUE/GREEN (-) Also Located At "Smart Entry Control Unit" Behind Left Side Of Driver Dash To Right Of Fuse Block. ------------- MO
Posted By: dare_ds69
Date Posted: August 15, 2005 at 6:30 AM
| 12volts | white | + | ignition harness | | Starter | BLACK / YELLOW | + | ignition harness | | Second Starter | BLACK/ white | + | ignition harness | | Ignition | BLACK/ red | + | ignition harness | | Second Ignition | | | | | Third Ignition | | | | | Accessory | white | + | ignition harness | | Notes: When doing remote start, this wire must be isolated from the keyswitch with the accessory relay. See direct fax document #1077. | | Second Accessory | | | | | Keysense | | | | | Power Lock | lt. GREEN / WHITE | - | anti-theft module | | Notes: The anti-theft module is located just above hood release cable in the drivers kick panel. Other wires at the anti-theft module are: 12V-WHITE/ red, ignition-green, ground-black, left door pin-gray/red, right door pin-blue, panic(horn and high beam)-YELLOW /GREEN. | | Power Unlock | brown | - | anti-theft module | | Notes: The anti-theft module is located just above hood release cable in the drivers kick panel. Other wires at the anti-theft module are: 12V-WHITE/ red, ignition-green, ground-black, left door pin-gray/red, right door pin-blue, panic(horn and high beam)-YELLOW /GREEN. | | Lock Motor | | | | | Unlock Motor | | | | | Parking Lights+ | RED / blue | | ignition harness | | Notes: There are two (2) RED / blue wires in the ignition harness, one is for parking lights and the other is for the right headlight. | | Parking Lights- | | | | | Hazards | | | | | Turn Signal(L) | | | | | Turn Signal(R) | | | | | Reverse Light | | | | | Door Trigger | RED / white | - | harness in driver kick | | Dome Supervision | | | | | Trunk/Hatch Pin | red | - | anti-theft module | | Notes: If not equipped with an anti-theft module, the red wire is located in a harness at the left trunk hinge. | | Hood Pin | yellow/black | - | anti-theft module | | Notes: The anti-theft module is located just above hood release cable in the drivers kick panel. Other wires at the anti-theft module are: 12V-WHITE/ red, ignition-green, ground-black, left door pin-gray/red, right door pin-blue, panic(horn and high beam)-YELLOW /GREEN. | | Trunk/Hatch Release | | | | | Power Sliding Door | | | | | Factory Alarm Arm | lt. GREEN/ red | - | anti-theft module | | Notes: The anti-theft module is located just above hood release cable in the drivers kick panel. Other wires at the anti-theft module are: 12V-WHITE/ red, ignition-green, ground-black, left door pin-gray/red, right door pin-blue, panic(horn and high beam)-YELLOW /GREEN. | | Factory Alarm Disarm | GREEN/ YELLOW | - | anti-theft module | | Notes: The anti-theft module is located just above hood release cable in the drivers kick panel. Other wires at the anti-theft module are: 12V-WHITE/ red, ignition-green, ground-black, left door pin-gray/red, right door pin-blue, panic(horn and high beam)-YELLOW /GREEN. | | Disarm No Unlock | | | | | Tachometer | yellow/red | ac | ECM in passenger kick | | Wait to start | | | | | Brake Wire | RED / green | + | brake switch | | Parking Brake | | | | | Horn Trigger | YELLOW /GREEN | - | anti-theft module | | Notes: The anti-theft module is located just above hood release cable in the drivers kick panel. Other wires at the anti-theft module are: 12V-WHITE/ red, ignition-green, ground-black, left door pin-gray/red, right door pin-blue, panic(horn and high beam)-YELLOW /GREEN. | | Memory Seat 1 | | | | | Memory Seat 2 | | | | | Memory Seat 3 | | | |
| Interface Module: | Category: Immobilizer Bypass | Required: No | Type: N/A | | Part #: N/A |
------------- how own your mind, control your life.
MECP certified. always use a DMM
