shaved door handle / solenoid / alarm ?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=61328
Printed Date: May 04, 2026 at 12:02 AM
Topic: shaved door handle / solenoid / alarm ?
Posted By: rtownsend
Subject: shaved door handle / solenoid / alarm ?
Date Posted: August 14, 2005 at 2:27 PM
This is my first post. I searched the forum post and couldn't find an answer.......I am currently trying to hook up 2 door solenoids in my 1994 mitsubishi 3000gt.... I have a Python 460hp model alarm and I am stumped on how too hook the solenoids into the alarm so that the drivers door works off the unlock button and the passenger side works off the aux button. Any help pointing me in the right direction would be greatly appreciated. Thanks.
Posted By: auex
Date Posted: August 14, 2005 at 2:37 PM
Hook the unlock output(should be blue in a 3 pin plug) to the driver's door soleniod through a relay and hook the RED / white wire in the primary harness up to the passenger's solenoid through a relay. You could also use the WHITE/ blue and program it to be a second unlock output and just hit unlock 2 times to pop the second door.
------------- Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
Date Posted: August 14, 2005 at 4:12 PM
Thanks. Just one more question.....does this look like the realy is hooked up correctly?
30 & 85 are hooked up to power in
86 ground
87 alarm [blue wire]
87a solenoid
thanks in advance.
