Alarm wiring advice
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=61342
Printed Date: May 04, 2026 at 7:52 AM
Topic: Alarm wiring advice
Posted By: Catnipsta
Subject: Alarm wiring advice
Date Posted: August 15, 2005 at 6:43 AM
Hi
I am planning to install a Toad Ai606 alarm to my VW Golf III, but I have one issue that I need to understand.  I am a bit confused with negative/positive tirggers (i.e. door triggers).  As shown in my VW  Golf manual's electrical diagrams, I know that the interior light/door trigger circuit is connected as follows: battery - light - trigger - ground.  From my electrical knowledge, I need to connect my alarm's trigger wire between the light and trigger.......am I correct? Is this called a negative trigger circuit and "going to ground"? or positive trigger circuit and "going to 12+ve" ?
many thanks in advance.
Posted By: dare_ds69
Date Posted: August 15, 2005 at 6:49 AM
Door Trigger blue/silver   -  blk box right of st. column
this is for 98 golf (uk)  negative door trigger means when you open the door this wire will read negative, with the door close should read nothing or 12 volts positive ok.posted_image
how own your mind, control your life.
MECP certified. always use a DMM
Date Posted: August 15, 2005 at 7:01 AM
Am I correct to understand that the wire you are referring to is the alarm wire to be connected between the light and trigger?   The state of this wire and the existing wire that connects the light to the trigger should be the same, right?
Is this also reffered to as "going to ground"?
many thanks dare_ds69 posted_image src="https://www.the12volt.com/installbay/smileys/smiley1.gif">
Posted By: riceman
Date Posted: August 15, 2005 at 7:47 PM
It's real simple what is the polarity of the door trigger when the switch makes contact when the door is open if it's positive the its a positive trigger if it's negative then it's negative. just connect to your alarm trigger wire to the corrosponding polarity . alarms have two wires for positive and negative , that way you can have that alarm hooked up into many different cars. just cut the one you dont need. good luck
