Module for Automatic Close Windows
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=61359
Printed Date: May 04, 2026 at 5:35 PM
Topic: Module for Automatic Close Windows
Posted By: samsagaz
Subject: Module for Automatic Close Windows
Date Posted: August 15, 2005 at 2:03 PM
Hey guys, i already installed 90% of the alarm (just need to install the kill starter relay) but i have another module to install
"Module for Automatic Close Windows" it close the open windows when the car is turned off, and central locking system lock the doors.
this module looks easy to install just need to put wires in the windows close system, an earth, and 12V, Central Locking sytem trigger wires.
the only problem that i have is one white wire labeled ACC, dont know where to plug this wire...
can someone help me?
THanks
Posted By: samsagaz
Date Posted: August 15, 2005 at 2:06 PM
Acc is the wire that show me 12V when the key is ON?
Posted By: mo12v
Date Posted: August 15, 2005 at 4:05 PM
Sounds right...............
Would be nice to know the Name & Model Number of Unit
MO
Posted By: samsagaz
Date Posted: August 15, 2005 at 5:01 PM
well its manufactured by Leadway, is an company from china, i ordered a few samples to test the quality of the products to start importing it to my country to resell..  The Model is LY-198.
i already installed it, but not lucky dont work. :(
i ear the internal swicth trying to close the window but the motor dont start closing the window, i think that this happend because my car need like 1" to press the key to start the motor to close the windows, and maybe this product just send the ground to my switch for less than 1"
ill attach the picture of the manual so you can see how it work.
i think that i do everything ok, but dont work in my car.
posted_image
posted_image
Posted By: endless talent
Date Posted: August 15, 2005 at 11:46 PM
Umm....wow.  That's a doozie of a manual.  Incorrect information and all.  My guess is that the "ACC" input is a negative trigger to open the windows, as with an "accessory" channel.  As most everyone here will probably agree, I swear by DEI and the other small companies out there doing this stuff...well just make sure you don't pay too much.
Posted By: samsagaz
Date Posted: August 16, 2005 at 5:22 AM
no, i dont pay too much, is cheap.
still without luck to get it running :(
Posted By: samsagaz
Date Posted: August 16, 2005 at 10:12 AM
hope someone understand abt that kind of products, the main unit need to close the windows after i turn the engine off and close the doors with the central lock system.
