bypass for 05 outback
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=61385
Printed Date: May 04, 2026 at 11:43 PM
Topic: bypass for 05 outback
Posted By: gregmeisman
Subject: bypass for 05 outback
Date Posted: August 15, 2005 at 6:10 PM
I'm installing an alarm in an '05 subaru outback.  Do I need any bypass module?
Greg
Posted By: Velocity Motors
Date Posted: August 15, 2005 at 6:21 PM
Yes you need a bypass module for this vehicle. There are keyless modules available as well as door lock modules for easier installations for the door lock systems. ( interface for Door Locks, Trunk, OEM Security Arm/Disarm, Panic.)
Posted By: dare_ds69
Date Posted: August 15, 2005 at 6:32 PM
12volts white (50A)  +  ignition harness
Starter WHITE/ black  +  ignition harness
Second Starter N/A
Ignition green  +  ignition harness
Second Ignition blue  +  ignition harness
Third Ignition N/A
Accessory yellow  +  ignition harness
Second Accessory N/A
Keysense BLACK/ white  +  ign harn or BIU, 28 pin plug, pin 7
Notes: The BIU (Body Integrated Unit) is to the right of the steering column.
Power Lock BROWN / white  -  dr. kick or BIU, 35 pin plug, pin 15
Power Unlock BROWN / black  -  dr. kick or BIU, 35 pin plug, pin 29
Lock Motor lt. GREEN/ YELLOW  5wi dr. kick or BIU, 35 pin plug, pin 7
Unlock Motor RED / green to lt. green  5wi dr. kick or BIU, 35 pin plug, pin 23
Parking Lights+ orange  +  parking light switch
Parking Lights- BLACK/ white  -  lighting switch
Hazards green to PURPLE / black  -  sw or turn signal and hazard module
Notes: The turn signal and hazard module is to the left of the steering column.
Turn Signal(L) blue / YELLOW  +  turn signal and hazard module
Turn Signal(R) RED / yellow  +  turn signal and hazard module
Reverse Light BROWN / yellow  +  passenger kick, harness to rear
Door Trigger see notes  -  BIU, 35 pin plug
Notes: The LF door is blue/white in pin 19, RF door is blue/orange in pin 32, LR door is yellow in pin 31, and RR door is WHITE/ red in pin 18. Use all four wires and diode isolate each.
Dome Supervision brown  -  BIU, 30 pin plug, pin 3
Also found in the passenger side A pillar.
Trunk/Hatch Pin lt. GREEN/ black  -  pass kick or BIU, 35 pin plg, pin 17
Hood Pin N/A
Trunk/Hatch Release WHITE/ black  5wi pass kick or BIU, 35 pin plg, pin 22
Power Sliding Door N/A
Factory Alarm Arm brown  -  dr. kick or BIU, 35 pin plug, pin 3
Factory Alarm Disarm yellow/red  -  dr. kick or BIU, 35 pin plug, pin 12
Disarm No Unlock see factory alarm disarm
Tachometer pink to RED / white  ac  ECM, 34 pin plug, pin 23 or cluster
Notes: The ECM is behind the glove box.
Can also go to a fuel injector under the hood and use the wire that is NOT blue/black (4 cyl), red (4 cyl turbo), or yellow/blue (6 cyl).
Wait to start N/A
Brake Wire BROWN / white  +  brake pedal switch
Parking Brake gray  -  sw or driver kick, harness to rear
Horn Trigger red to RED / white  -  column or BIU, 30 pin plug, pin 11
Memory Seat 1 N/A
Memory Seat 2 N/A
Memory Seat 3 N/A
posted_image
Interface Module:Category:
Immobilizer Bypass
Required:
Yes
Type:
Transponder
Part #: 556UW
Alternate Part1 #: 555U
Notes: Standard on all models except the 2.5i Wagon, and 2.5i Limited Wagon.
how own your mind, control your life.
MECP certified. always use a DMM
