radar sensor
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=61483
Printed Date: April 24, 2026 at 8:01 PM
Topic: radar sensor
Posted By: ryan_88
Subject: radar sensor
Date Posted: August 16, 2005 at 10:23 PM
ok, so my rader sensor has two outputs. exterior of the vehicle and interior of the vehicle. when i connect these to the alarms input, do i use a diode for each? also, does anyone know a good place to mount this in a '97 jeep wrangler?
ryan
Posted By: endless talent
Date Posted: August 16, 2005 at 11:29 PM
If you are using a DEI alarm system, it will have a BLUE instant trigger wire that can distinguish the difference between a negative pulse lower or higher than 0.8 seconds. This will give the alarm the ability to read the difference between a Warn-Away pulse and a Full-Trigger pulse. The DEI 508-D radar sensor outputs the Warn-Away on the light green wire and the Full-Trigger on the light blue wire, so you would simply diode-isolate each (with the striped end of the diodes facing the radar sensor) and send each to the blue instant trigger wire. I you do not have a DEI system, read the details on any instant or multiplex inputs available at the brain or tap into the external shock sensor.
