'92 Astro Van, air condition/remote start
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=61502
Printed Date: April 24, 2026 at 12:57 PM
Topic: '92 Astro Van, air condition/remote start
Posted By: MadsDK
Subject: '92 Astro Van, air condition/remote start
Date Posted: August 17, 2005 at 4:43 AM
Hi There,
In short terms I'm installing a remote start alarm in a Astro Van '92.
Everything is ok, all wires connected and it start fine by remote. The thing is that when I connect the "Aircon/electronic gaugedash" wire to the alarm, it won't remote start. The alarm, by the way Royaltek ht800, turns on the ignition for just a second and then aborts. It is like it gets an error or somehow thinks that the ignitionkey is in and turned or something.
I've tried to have only the aircon wire (ORANGE) connected to the alarm and no other wires from the ignition lock and it still does the same.
I've tried putting a relay in between the alarm and the aircon wire to see if the reason was overloading the alarm, no difference. I've also tried connecting this to the different ignition outputs on the alarm, (acc, ign, on...)
Anyone who knows if i'm totally off-track or some hints would be appreciated very much.
Thanks - Mads Poulsen
Posted By: dare_ds69
Date Posted: August 17, 2005 at 6:57 AM
12volts red   +  ignition harness
Starter yellow   +  ignition harness
Ignition pink   +  ignition harness
Accessory orange   +  ignition harness
thas the wires that you need to power during remote start.
how own your mind, control your life.
MECP certified. always use a DMM
Posted By: MadsDK
Date Posted: August 17, 2005 at 9:26 AM
Thanks, as i wrote, I have tried the orange wire, and it's just so weird that it aborts remote start when trying to put +12v to this wire..
Just wondering if anyone had been in this situation or somelike.. But thanks Dare!
-Mads
Date Posted: August 17, 2005 at 5:36 PM
you best choise is try to go to the ignition harness behind the key cilinder and see howmany wires are behind it and the colors.
