dead viper remote
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=61628
Printed Date: March 28, 2026 at 5:49 AM
Topic: dead viper remote
Posted By: hot00boy
Subject: dead viper remote
Date Posted: August 19, 2005 at 2:43 AM
hey
i have a viper 790xv alarm with the 1-way 472 remotes.  2 days ago everything was working perfectly but the light on the remote seemed to get dimmer and dimmer.  After a bit longer the remote totally stopped working over night.   I changed the battery and still no response from the brain.  I also tried reprogramming it to the brain and still nothing.  i then unplugged all the wires from the unit for about an hour and plugged everything back up.  Still no response from the unit.  What else could solve this problem?  could the remote be out of sync with the brain or something because i believe the code hopping was active.  also what battery goes in the remote?  it had a 2032 in it so i replaced it with another 2032.  is this the correct battery because i have known people to confuse 2032 batteries with 2025 because they are the same size.
1993 Buick Roadmaster
Posted By: firstclassohio
Date Posted: August 19, 2005 at 9:08 AM
you can use one 2032 or 2 stacked 2016's. does the light come on on the remote?
under promise and overdeliver
Posted By: hot00boy
Date Posted: August 19, 2005 at 12:16 PM
yes the remote does light up when a button is pushed.
Date Posted: August 19, 2005 at 12:40 PM
take the white with blue stripe and tap it to ground and see if remote start fires up
Posted By: hot00boy
Date Posted: August 19, 2005 at 12:50 PM
yes it remote started when i tapped the wire to a ground
Date Posted: August 19, 2005 at 1:29 PM
take the white wire w/ blue stripe and tap it to ground, this should cause the remote start to engage. see if this works
Date Posted: August 19, 2005 at 1:31 PM
do you have the second remote? try it if not do you have a bitwriter? zap the unit to clear all remotes and try programming it again
Posted By: hot00boy
Date Posted: August 19, 2005 at 1:51 PM
i do not have a second remote or a bit writer.  i tried reprogramming it on multiple occasions.  what did it mean when it remote started when i tapped the wire to a ground?  i was trying to avoid buying another $100 remote.  is there any other way i would be able to get it working again?
Date Posted: August 19, 2005 at 3:03 PM
I was making sure the unit wasn't dead, the wire just showed that the unit still works. I would have to say the remote is not working, help me out here. i am a python dealer, you have a viper which is the same but the part numbers are different, is this not a 2 way piece or is it?
Date Posted: August 19, 2005 at 3:07 PM
if it is the 4 button 1 way then the remotes are only about $25, Most DEI dealers can warranty them if they are not being p***ks. DEI says there  is only a 1 year warranty on their remotes but I have never seen them enforce it. the 2 way is $75 dealer cost but I have always gotten them warrantied!!
Posted By: godblessdremil
Date Posted: August 20, 2005 at 11:33 PM
AS long as it is not due to customer abuse most DEI dealers will warranty it.
Posted By: blazeronspokes
Date Posted: August 21, 2005 at 2:09 AM
if you purchased the alarm from a retailer like best buy you could probubly go there and have them swap it for the newest equivalent. they warrenty all DEI alarms purchsed from them for the life of the vehicle.
