How to steal your car in 3 seconds
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=61779
Printed Date: May 16, 2026 at 8:11 AM
Topic: How to steal your car in 3 seconds
Posted By: timk053
Subject: How to steal your car in 3 seconds
Date Posted: August 21, 2005 at 12:00 PM
So, not knowing any car theives, How do they do it? In the interest of building a security system that works a little, it would be helpfull to know the basic steps a pro would use to get your ride. I'm thinking , of some diversionary wires and air horns instead of the cute little siren. Perhaps a flash bang wired under the dash? Thanks in advance
Posted By: Velocity Motors
Date Posted: August 21, 2005 at 1:00 PM
Protect your battery at all costs & get a back up battery as well with an alarm system that is 2 way. All the bells and whistles do you no good if the battery wires are cut.
------------- Jeff
Posted By: timk053
Date Posted: August 21, 2005 at 2:49 PM
Good point, is it common for a pro to go to the trouble to disconect the battery, disable the alarm, then reconnect the battery to drive away?
Date Posted: August 21, 2005 at 3:48 PM
If you want to protect the car and it's contents and have a chance of catching the theif you have to think that if the thief disables your system, they have all the time in the world to take what they want and also disable the steering lock and they can ( if they want to ) roll the car or place it on a tow truck and drive it away. ------------- Jeff
Posted By: timk053
Date Posted: August 21, 2005 at 8:16 PM
I guess that makes good sense. I was thinking more allong the lines of trying to slow down someone in a hurry who would break glass, ignore the siren, cut some wires, jimmy the ignition and drive off. Something a little unexpected that might take them a bit longer to work out, dummy relays, hidden switches, change some color codes etc. Or by not advertising the fact that the vehicle is armed, I got to think that my air horns going off 2ft from some smuck in the middle of the night might get them to change their plan, or at least change their pants. But then, why not do both thanks for your time. TimK
Posted By: godblessdremil
Date Posted: August 21, 2005 at 10:11 PM
Back up siren, hide your main unit, more importantly the wirings as well. Don't do it in te open, make everything look stock. A hidden starter kill, dummy wiring/ headunit. And that airhorn cave me an idea, make it so when the alarm is set off a timer begins its run and just when the guy is in there like 20 15-20 seconds, make it go off and keep going. Oh ya get a 2-way that way you can stand behind them with a pipe/ gun when they decide to leave.
Posted By: timk053
Date Posted: August 21, 2005 at 10:42 PM
I'm loving the airhorn delay. Any ideas how to wire the timer without getting on the terrorist watch list.
Date Posted: August 21, 2005 at 11:29 PM
Use the DEI timer module for this. ------------- Jeff
Posted By: Fastlearner
Date Posted: August 22, 2005 at 4:15 AM
Have your exsisting ignition harness become a fake harness. then rewire your key cylinder hidden in like the center consul or behind a fake panel on the dash, that way he couldn't jimmy the key cylinder. Just something i just thought of while reading and i might actually do it to my car.
Posted By: OhioMike1101
Date Posted: August 22, 2005 at 7:45 AM
maybe it is just me, but I have my alarmmostly as a deterrent. If someone wants the car that bad.... they can have it. That is what insurance is for.
Hopefully the starter kill, 2way, etc... will slow them down as I have an Autopage RS-720LCD, but i have the alarm as a deterrent and mostly for the features of RS, KE, etc...
I park in a garage at night and only arm the alarm at work and the mall. At work, my car is less than 50 feet away from my window.
Posted By: 5150azn
Date Posted: August 22, 2005 at 11:00 AM
Damn guys I grew up in Fresno which was once GTA capital of the world. You guys are damn paranoid. All you need is a back up battery. Thats it! The pros will break in and disconnect your battery. Then they can do with your car as you wish. But with a back up battery that is properly installed the theif will have to get under the dash and try to figure out the install. Thats too much to ask of a guy thats trying to make a quick getaway.
------------- Tell the Snap-On guy I'm not here!
Date Posted: August 22, 2005 at 5:51 PM
Hey he wanted ideas and another thing make sure that timer/ sirhorn stops when ya disarm or someone in your nieghbor hood is gonna put a pipe to it.
Posted By: auex
Date Posted: August 22, 2005 at 5:56 PM
2 words.
TOW TRUCK!!!
------------- Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
Posted By: 5150azn
Date Posted: August 22, 2005 at 6:46 PM
auex] wrote:
2 words.
TOW TRUCK!!!
I know dude! You know whats funny is when you really need a tow they take like 30 mins hooking it up. ------------- Tell the Snap-On guy I'm not here!
Date Posted: August 22, 2005 at 6:52 PM
That's what I said in my first post.  ------------- Jeff
Posted By: hurleyloser
Date Posted: August 23, 2005 at 2:12 AM
my gf lost her remote at a theme park, so having some alarm knowledge, i just popped the hood disconnected the battery, got under the dash and disconnected the alarm module, which i just reached under the dash and moved my hand around to find... then i just connected the battery and we drove off. if someone really wants your car, they'll take it, no matter what... but if you wanna give the average car theif a hard time.. get a battery back up... interior sirens like the air horn.. thats a good idea.. in addition to the battery back up get a hood lock, which you can get from dei.. incase they prop that open and disconnect your battery you stil have the backup... hide your internal wiring as well as your alarm module and your sirens, make everything as difficult as possible to get to. as far as preventing the theft of your head unit or audio system.. use uncommon screws to fasten them to your vehicle as oppose to the traditional phillips.. maybe even those locks they sell for laptops... i donno. those are just some things to consider..
Posted By: blazeronspokes
Date Posted: August 23, 2005 at 10:19 AM
what i did for mine was this: relocated the alarm brain(don't just have it hanging in with the ignition harness) add back up battery i have 13 sirens on mine(6 outside under the hood, 4 in the rear outside, 2 piezo's inside, and 1 regular 514n inside) a digital tilt sesor proximity sensor remote hood latch(i used a solenoid to pop my hood and bolted the hood release cable to my firewall, this way if they try to break the window and pop the hood they will be in for a suprise!) all of the wiring for my alarm is the same color wire 2 way paging alarm and make sure to loom and tape everything so it looks stock as possible All of these work great as a theft deterent. just remember that it is only a theft deterent. if somebody wants your car, there gonna get it one way or another. all you can do is make it as difficult as ppossible for them to do so. hope this helps with some ideas. happy installing!
Posted By: 5150azn
Date Posted: August 23, 2005 at 11:24 AM
add back up battery
proximity sensor
2 way paging alarm
Jesus Christ! ------------- Tell the Snap-On guy I'm not here!
Posted By: Satkunas
Date Posted: August 23, 2005 at 12:09 PM
LOL.
I just need to throw a rock at your car and come back in 30 seconds when your battery is dead.
Date Posted: August 23, 2005 at 3:58 PM
Hey i gotta give him credit for it, but 12 sirens? Little over kill don't ya think.
Posted By: 03taurus
Date Posted: August 23, 2005 at 5:31 PM
How in the hell does the solenoid pop open your hood if you had a dead battery? And how do you change the dead battery that is under the hood? Are 4 sirens going off really that much louder then just 1 under the hood? I do give you credit, but remember one thing, It only takes 5 seconds for a tow truck to lift the back of your car up and take it down the road a mile or 2 and strap it down. I see people park in the wrong parking lots on Miami Beach and they snag em' out there all the time. Kinda funny actually. If I was as paranoid as you I would put an ancor in the ground 4 feet down and about 30 Cu. Ft. of concrete around it and a chain it down with some 80 grades stainless steel chain. I think the 1 1/4" chain should do ya. Actualy to help ya out i included a link on where to buy the chain. https://https://www.gatorsupply.com/chnssalys.htm
Posted By: 5150azn
Date Posted: August 23, 2005 at 5:42 PM
Lmao! hahahaha! Gosh this is almost as good of a laugh as I got from the stang!
True story. I pulled up to the gas station near my house. 2 girls are looking at eachother with a worried look on their faces. I see the driver climb to the back hatch area of the civic and try to open the hatch. It then occurs to me that this primered, lowered, civic has shaved door handles. lol They were stuck inside the civic! The driver climbs back to the driver's seat and turns the key in the ignition... Nothing. Dead battery. LOL
Date Posted: August 24, 2005 at 12:21 PM
sorry 03taurus, i forgot to mention that i have a pair of posts mounted to the bottom of my bumper for the occasion that my battery is to fail. all i gotta do is hook a pair of jumpers to it and boom, i'm back in my car. like i said before though, i only do this stuff to help prevent my car from being stolen/ broken into. all you can do is try, if they want your car bad enough, they're gonna get no matter what you do. and yes, four sirens going off is really a lot luder than one. when my alarm goes off, you practically go deaf. i love it.
Posted By: 03taurus
Date Posted: August 24, 2005 at 4:40 PM
OK that makes much more sence. Just keep the water off of those jumpers and your good to go. I am jelous actually now.
Posted By: 5150azn
Date Posted: August 24, 2005 at 6:02 PM
Hey is it still security when you chain your wheel to the lamp post? If it works for bicycles it should work for a car.
Posted By: timk053
Date Posted: August 24, 2005 at 8:30 PM
Yahoo!! .....smoking good info, wiring brain overload.  So let me recap..... I need 10-12 more sirens, seems like air horns ought to count for 2 or 3, another battery (or two), someting called a pipe gun, 12 ga I'm guessing, a countdown timer from DEI (wonder if Jr. makes em), a really nice chain, some concrete, lots more tape, some odd screws, another battery, rock deflector, jumper cables, another ignition harness, more tape, oh... and pay my insurance. Sounds like I've got some shoping to do.... Lots of good info thx.  timk
Posted By: gcorrea
Date Posted: August 26, 2005 at 12:45 AM
i just leave my rott in my trucks bed, he doesnt like people.
------------- gcorrea
Posted By: aurora4.0
Date Posted: August 26, 2005 at 1:38 PM
Check out this product: Ravelco Anti Theft Device. Lots of good information about how no one has ever been able to "hotwire" a car with Ravelco. www.neverstolen.com
Posted By: 5150azn
Date Posted: August 26, 2005 at 1:49 PM
www.neverstolen.com
LMAO what the eff is that? ------------- Tell the Snap-On guy I'm not here!
Posted By: geoffl
Date Posted: August 26, 2005 at 3:50 PM
the ravelco really works. even if the car is on and you pull it off the car will die immediately. its good.
------------- Geoff
Date Posted: August 26, 2005 at 10:51 PM
ya but how the **** does it work its kinda vauge an't it.
Posted By: 6061dyson
Date Posted: August 27, 2005 at 9:10 AM
Park your car next to a much more desirable car! Modded cars are probably the best being flashy!
Do you not have immobilizers?
All cars since 1997ish for England were built with immobilizers! The best thing thats come outta this "sue you, sue you" hateful era
