DEI 688M, blue wire, Negative ignition?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=62160
Printed Date: May 12, 2026 at 9:17 PM
Topic: DEI 688M, blue wire, Negative ignition?
Posted By: lak8
Subject: DEI 688M, blue wire, Negative ignition?
Date Posted: August 27, 2005 at 9:46 PM
Hello, i have a python 880xp alarm/car starter. Im installing the DEI 688M neutral safety module. Every thing is connected, but one wire that i need to know were it goes. Blue wire - Negative ingition from car starter. (on the blue wire itself it has a sticker on it that reads quote: "Warning! This wire must be connected to a negative ingition only! Do not connect to the status wire of the remote car starter. Do not share the ground feeding this wire with any other device. It must be connected as a "stand alone" only!" Thanks Daniel
Posted By: KarTuneMan
Date Posted: August 28, 2005 at 12:57 AM
ALL of the DEI instructions are written for people who have done HUNDEREDS of installs...I think they stink for the newbie or the "not so skilled" installer....I've been doin this for 20 years.....and some of the DEI stuff don't make sence to me! Vague at best.............DEI OK, Im ready for the crap............ -------------
Posted By: lak8
Date Posted: August 28, 2005 at 10:11 AM
KarTuneMan do you happen to know what it would go to. Im hopeing to get it wired up today, so i can have my car for monday :(
Posted By: lak8
Date Posted: August 28, 2005 at 10:21 AM
I was just looking at my alarm install manual and i have some wires that i think it may go to but im not sure. Remote Start Harness (H3) 1 - Blue: (-) Status/Factory Security Rearm Output (((I dont think i should connect it to this sence it states on the 688m ("Do not connect to the status wire of the remote car starter"))) 2- Blue/Black: (-) 200mA Optional Third Ignition Output (((Should i connect it to this? this was my closest guess but i dont want to short anything out.)))
Posted By: extreme1
Date Posted: August 28, 2005 at 10:25 AM
on your relay pack there's a small 4 pin harness, connect the blue wire on the 688m to the pink wire on that harness...
------------- Shaughn Murley
Visions Electronics
Red Deer, Alberta
Posted By: extreme1
Date Posted: August 28, 2005 at 10:26 AM
oh, if it's an older style with the exposed relays, just connect it to the pink in the ribbon cable
Visions Electronics
Red Deer, Alberta
Posted By: lak8
Date Posted: August 28, 2005 at 10:35 AM
I do have a ribbon cable with 5 wires. The pink wire is: 3 - Pink: (-) 200mA Ignition Relay Turn-On ((( So i should connected it to this wire? these seem to be all factory joints. I just want to confirm that i do in fact connect it to this?)))
Posted By: lak8
Date Posted: August 28, 2005 at 10:42 AM
I also wanted to mention that it says on the 688m sticker on the blue wire, that i need to know were it goes "Do not share the ground feeding this wire with any other device. It must be connected as a "stand alone" only!" so can i connect to the ribbon cable still sence its already feeding the relay for the remote starter. im so confused heh
Posted By: kgerry
Date Posted: September 06, 2005 at 6:20 PM
yes as mentioned connect it to the pink ign 3 relay turn on lead... this should be a free wire... it should also be on a 4 wire harness coming off the back of the XCSR pack
------------- Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
