99 Ford Windstar/Viper 100 Keyless Entry
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=62250
Printed Date: May 12, 2026 at 3:02 AM
Topic: 99 Ford Windstar/Viper 100 Keyless Entry
Posted By: BOB1
Subject: 99 Ford Windstar/Viper 100 Keyless Entry
Date Posted: September 05, 2005 at 9:15 PM
The Viper keyless entry remote when pushed unlocks all doors the first time I push it, after that it will only lock & unlock the two sliding & rear doors. I can see the door lock on the driver side try to move a little in lock or unlock. Also the front locks wont work by using the door lock switch. The Viper 100 unit worked fine for about 2 years. Is the problem in the keyless unit, the door switch, or the actuator? Thanks for the Help, Bob
Posted By: auex
Date Posted: September 05, 2005 at 9:42 PM
If it don't work with the factory switches and the remote then it is probably the actuators.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
