Clifford RSX3.5 Does It Support Stick Car
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=62295
Printed Date: May 11, 2026 at 6:20 PM
Topic: Clifford RSX3.5 Does It Support Stick Car
Posted By: newinstaller
Subject: Clifford RSX3.5 Does It Support Stick Car
Date Posted: September 06, 2005 at 6:22 PM
Hi,
I am used to Compustar 2W900FMAS for manual. Does the Clifford RSX3.5 Support Manual cars? If not is there a module to use? How safe is it?
Any feedback from other dealers is appreciated. Also how is the unit overall?
Posted By: redpeppers
Date Posted: September 06, 2005 at 11:37 PM
3.5 does not support manual trans. starting....not very safe unless your manual car has a neutral saftey switch wire....most manual car don't.....
Where theres is a wire there's a way.
Posted By: xtremeaudio
Date Posted: September 07, 2005 at 3:36 AM
you may check out on new clifford g5 will work with manual tran
