05 altima remote start
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=62306
Printed Date: May 11, 2026 at 12:50 PM
Topic: 05 altima remote start
Posted By: jack987
Subject: 05 altima remote start
Date Posted: September 06, 2005 at 8:20 PM
I would like to install a remote starter that I had in my old car into my new car.
The remote starter is a Power start P-9000 that I had installed in a Chrysler Intrepid 1994, I would like to install the remote starter in a new Nissan Altima 2005.
I would like to know which transponder bypass I need for a Nissan Altima 2005, V6 3.5 automatic and also if you would have the wiring for the Nissan Altima (where all the wiring connections are made and color codes of the car.)
Thank You very much for your help.
Posted By: gcorrea
Date Posted: September 07, 2005 at 1:23 AM
transponder model #556uw
12 volts= green wire 40 amp at ign.
starter= BLACK/ red at ign.
second starter= BLACK / YELLOW at ign.
ignition= BLACK/ red at ign.
accessory= red at ign.
second accessory=WHITE/ blue at ign.
keysense=black red at ign.
power lock=brown at bcm
power unlock=pink at bcm
parking lights+= RED / blue at drivers kick panel
door triggers=lf -liteblue, rf-pink/blue, lr-RED / black, rr-RED / white at bcm diode isolate each wire.
dome supervision=red at bcm
trunk-=RED / black or blue/red at bcm
factory alarm arm=pink/blue at drivers door module
factory disarm=WHITE/ blue at drivers door module
tach= any fuel injector
brake wire=RED / green at brake switch
gcorrea
Posted By: Teamrf
Date Posted: September 07, 2005 at 8:08 PM
Remote starts....fun fun fun...use a DMM not a test light..good luck. Post if you need help. I love alarms.
~The Rookie~
Rookie of the year that is...
Don't let the smoke out of your equiptment..it doesn't go back in.
Posted By: Teamrf
Date Posted: September 07, 2005 at 8:11 PM
~The Rookie~
