99 escort zx2
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=6246
Printed Date: May 09, 2026 at 7:11 AM
Topic: 99 escort zx2
Posted By: freakystyley990
Subject: 99 escort zx2
Date Posted: December 04, 2002 at 7:31 PM
can someone give me  a wiring diagram for a 1999 ford escort zx2?
FreakyStyley990
Posted By: securinu
Date Posted: December 04, 2002 at 9:37 PM
Car Wire Profile for 1999 Ford Escort
 Wire ColorLocationInstructions
StarterRed / Wht.Ign Harness..
Notes:
Ign.#2: Blk / Wht is located in the ignition harness base of the steering wheel. Brake switch: Green ( + ) at brake switch Trunk Release: Grn / Blk ( - ) located passenger relay module.
T-Harness Info
Starter Disable/Power:.
Door Lock:..
Complete Alarm Harness:.
Remote Start:.
Factory Keyless Upgrade:.
Technical Bulletins Related to this vehicle:
Constant 12VBlk / Org.Ign Harness..
Switched 12VGry / Yel.Ign Harness..
Dome LightRed / Wht.under fuse box.( - ).
Parking LightsRed / Blk.15 pin grn conn dr. kick..
HornYel / L. Grn.Ign Harness.( - ).
Door LockBlue.dr. kick / pass kick.( - ).
Door UnlockGrey.same.same.
Power Trunk...
Left Front Window...
Right Front Window...
Keyless Module...
TachometerYel / Blue...
Trigger Lock...
Trigger Unlock...
Unlock Monitor...
Unlock Monitor (Factory Alarm)...
Other:
