driver unlock priority
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=62611
Printed Date: March 24, 2026 at 3:15 AM
Topic: driver unlock priority
Posted By: gcorrea
Subject: driver unlock priority
Date Posted: September 12, 2005 at 11:33 PM
im looking for a driver unlock priority relay diagram, but instead of using the actuators for the lock unlock feature i need to pop the doors(selonoids) in the same manner as you would the actuators. is this possible without using an extra aux channel?
gcorrea
Posted By: auex
Date Posted: September 12, 2005 at 11:50 PM
Generally it is just - to + using the unlock output for the driver's door and the second pulse/aux pulse for the passenger's doors. To have true progressive unlocking the alarm has to be capable.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
Posted By: gcorrea
Date Posted: September 13, 2005 at 1:00 AM
the instructions show how to wire progressive door locks but doesnt go into much detail since you have to use one of their relay harnesses that plugs into the alarm. so i guess i would have to use the pulse from the unlock wire to pop the drivers door and the aux pulse to pop the pass. door. right? what happens to the lock wire (pulse) since i dont need to lock anything any more. the alarm is a k9 classic. thanks.
gcorrea
Posted By: mo12v
Date Posted: September 13, 2005 at 7:57 AM
You could use the Lock first then Unlock second
OR
I think OMEGA makes a Pulse Expander DLP ?? & DLS?? or they used to have a REC 43 that had 4 different Programmable Outputs..........
I would Relay ALL Outputs
MO
