door lock trigger
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=62825
Printed Date: March 19, 2026 at 2:49 PM
Topic: door lock trigger
Posted By: lodime
Subject: door lock trigger
Date Posted: September 17, 2005 at 9:00 PM
I have recently put in a viper 791xv  alarm. Here's what i want to accomplish.
Say the alarm is armed, doors are locked, but windows are open. When a person reaches inside and unlocks the door (without actually opening the door) i want the alarm to go off.
Any ideas on how i can pull this off? Ive got aftermarket door locks, 5 wire actuators... I tried connecting the door trigger input wire on alarm to the - unlock on the actuator module, but that didn't seem to work...
thanks
Posted By: mo12v
Date Posted: September 17, 2005 at 9:25 PM
What wire from 791 did you use?
Were you trying to connect to Door Lock / Unlock Relay Module or did you try at the Actuator wires?
When you Unlock one of the Actuators the Lock wire at the Actuator should become Negative & visa versa
MO
