Galaxy 5000 RSW lock/unlock
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=62893
Printed Date: March 18, 2026 at 6:56 AM
Topic: Galaxy 5000 RSW lock/unlock
Posted By: mndiver
Subject: Galaxy 5000 RSW lock/unlock
Date Posted: September 19, 2005 at 9:41 AM
I need some advice on my new install of a Galaxy 5000 RSW. This was installed on a 2003 Dodge Dakota V8 Automatic. Since this is a single wire system in the Dodge, I have two relays hooked up to the two wires (Lock/Unlock) from the RSW and am using two resistors as pull-ups for the Dodge connection. One resistor is a 330 ohm and the other is a 820 ohm.
The remote will not unlock or lock the doors. I am looking for any suggestions.
Posted By: mo12v
Date Posted: September 19, 2005 at 11:00 AM
Be sure the Resistors are AFTER the Relays...( between the wires going to the Factory WHITE / Dk.Green wire )
And U have a GOOD Ground Pulse from Relays
Similar to this:
https://www.wiringinstructions.com/217.htm
Power LockWHITE/ DARK GREENAT CONTROL MODULE
Power UnlockSINGLE WIRE SYSTEMIN DRIVER KICK **
** Single Wire Door Lock System, WHITE/ DARK GREEN Wire Requires Chassis Ground Thru A 820 Ohm Resistor To Lock And Chassis Ground Thru A 330 Ohm Resistor To Unlock.(
MO
