Crimestopper/ Dome light
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=62949
Printed Date: March 18, 2026 at 3:47 AM
Topic: Crimestopper/ Dome light
Posted By: jumargibbs
Subject: Crimestopper/ Dome light
Date Posted: September 20, 2005 at 5:49 AM
After finishing the install of a CS-200TW1, I decided to add an additional "feature" which turns on the dome light for 30 sec. upon disarm. However, this feature defeats another feature, that being Active Re-arm. This program will re-arm the alarm in case of an accidental disarm IF no doors are opened, but upon disarm, the dome light goes on and that tells the brain a door has been opened and it will not automatically re-arm. Is there any way around this or should I use one of the auxillary buttons to control the dome light?
Thanks for all of your help,
      Ken
Ken
Posted By: gcorrea
Date Posted: September 20, 2005 at 9:41 PM
crimestoppers is made by omega research, if its like the k9s then you have to remove the jumper insert on the brain when using both the negative door trigger wire and the domelight supervision. instead of just using the domelight supervision wire to trigger both the doors and the domelight.
gcorrea
Posted By: gcorrea
Date Posted: September 20, 2005 at 9:44 PM
cimestoppers is made by omega reaserch, if the wiring is like the k9s then you must remove the jumper pin on the side of the brain. unless you use the domelight supervision wire to trigger both the doors and the domelight.
gcorrea
Posted By: gcorrea
Date Posted: September 20, 2005 at 9:47 PM
sorry for the double posts,but when i hit the post reply it tells me that it didnt post. also, what car is this?
gcorrea
Date Posted: September 21, 2005 at 6:21 AM
1988 Ford Ranger
Thanks for posting
Ken
Ken
