audiovox door lock relay?2005 F250
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=62962
Printed Date: March 17, 2026 at 4:53 PM
Topic: audiovox door lock relay?2005 F250
Posted By: Fastlearner
Subject: audiovox door lock relay?2005 F250
Date Posted: September 20, 2005 at 11:21 AM
Doing a keyless entry onto a 2005 F250 Super Duty. The Door lock relay doesn't have a Diagram for it. How should i hook up the wires if they are a 5-wire system.
lock-pink / YELLOW
unlock-pink/lt. green
Posted By: sneakycyber
Date Posted: September 20, 2005 at 11:26 AM
https://www.the12volt.com/doorlocks/page3.asp#5w That shows you the diagram for 5 wire
Date Posted: September 20, 2005 at 11:35 AM
It already comes with a door lock relay. I'm not to sure though about one wire. It's a RED / white wire coming from the relay. Also, should i put the purple wire to ground or twelve volts for a five wire.
