2002 Nissan Maxima Remote Start, Auto
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=63006
Printed Date: March 15, 2026 at 9:22 AM
Topic: 2002 Nissan Maxima Remote Start, Auto
Posted By: nyeddie
Subject: 2002 Nissan Maxima Remote Start, Auto
Date Posted: September 20, 2005 at 11:33 PM
hey whats up guys? I'm installing a remote starter on my car and I wanted to ask a few questions, maybe someone knows, maybe not..
U got the 561T unit.
1)) WHITE/ RED (+) activation input -- is that the (+) from the door locks? i dont get it.
2)) RED / WHITE (-) 200mA channel 2 output -- isnt that already the lock/unlock of the factory remotes.
3)) YELLOW (-) ignition output -- that goes to the ignition obviously?
4)) WHITE/ blue (-) activation input -- do i use the positive or the negative activation input?
******* now as for the other wiring..
- PINK 200mA third ignition turn ON
- PURPLE (-) 200mA second starter turn ON
- ORANGE (-) 200mA accesory turn ON
- BLUE (-) 200mA status output
where do these go? I have no idea.
I really appreciate any help I get. have a good night guys.
eddie
Eddie
Posted By: nyeddie
Date Posted: September 20, 2005 at 11:39 PM
these im guessing i dont use..
Eddie
Posted By: redpeppers
Date Posted: September 21, 2005 at 12:24 AM
white red and white blue is not used unless u are installing a alarm seprate the remote start....RED / white is for (example) trunk pop or whatever u want....yellow is used to trigger a alarm...and no it most diffently does go to the ignition (that could cause major problem if u hook it TO THE igntion).....and as for the other four color they are for seperate relays if needed.....depeands on the car
Where theres is a wire there's a way.
Date Posted: September 21, 2005 at 12:26 AM
let me know if u have more questions....dont hook anyhting up unless u know what it is for....it will save u alot of headache
Posted By: nyeddie
Date Posted: September 21, 2005 at 1:04 PM
so yellow to trigger alarm.. and the others i dont need to use? I'm installing this on a 2002 maxima automatic with an alarm already in it.
Eddie
Posted By: nyeddie
Date Posted: September 25, 2005 at 1:05 PM
I know it should be (-) when the remote starter is activated but what wire does it connect to?
Eddie
Posted By: mo12v
Date Posted: September 25, 2005 at 1:12 PM
Depends on the Remote Start Unit..........
Try MORE INFO?????????????????
MO
Posted By: nyeddie
Date Posted: September 25, 2005 at 2:25 PM
sorry its the 561T unit. and i'm hooking it up to a 02 nissan maxima
Eddie
Posted By: iskidoo
Date Posted: September 25, 2005 at 3:02 PM
H2/5 BLUE/WHITE status/factory security rearm output
Steve G
Posted By: mo12v
PAGE 21 ...Install Manual
BLUE or BLUE / White
MO
Posted By: nyeddie
Date Posted: September 25, 2005 at 9:01 PM
Hello, I'm installing the 561T with 555U in a 2002 nissan maxima. Ive found the wires and only slit two of them to make sure that they were it.
So now i had to move the car.. so i tape them back up and put everything back together and now the brake light is on and isn't going away? Is there a way to fix that, do i need to discount the battery terminal? or will it fix itself?
Has anyone installed a remote starter on an 02 maxima before? Im looking to hook up the unlock/lock wires for the remote start and was looking for something closer inside the cabin, other than taking the door off and going from there.
thanks a lot for your help guys, i really appreciate it.
Eddie
Posted By: Hornshockey
Date Posted: September 25, 2005 at 11:56 PM
Lock Motor gray    pin 54 at SECU
Unlock Motor WHITE/ black pin 55 at SECU (both 5 wire hookups)
The SECU (Smart Entrance Control Unit) is located to the passengers side of the steering column.
Life moves pretty fast; if you don't stop and look around once in a while; you could miss it.
Date Posted: September 25, 2005 at 11:57 PM
wow; I apologize for the discombobulated look of my last post; it didn't look like that when I entered it
