1998 ford contour svt wiring guide
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=63067
Printed Date: March 14, 2026 at 7:18 AM
Topic: 1998 ford contour svt wiring guide
Posted By: groenenk
Subject: 1998 ford contour svt wiring guide
Date Posted: September 22, 2005 at 9:42 AM
Can someone link me to the wiring guide for the 1998 ford contour svt at directechs.com?..this would be greatly appreciated
Nate Groenewold
Posted By: mo12v
Date Posted: September 22, 2005 at 9:59 AM
Posted By: mo12v
Date Posted: September 22, 2005 at 10:00 AM
Constant 12 voltsREDIGNITION SWITCH HARNESS
Ignition 12 voltsGREENIGNITION SWITCH HARNESS
StarterGRAY/WHITEIGNITION SWITCH HARNESS
Dome LightBLACK/ BLUE (-)10 PIN CONN. ON BACK OF FUSE BLOCK
Trunk Pin SwitchBLACK/ ORANGE (-)AT LIGHT IN TRUNK *
Parking LampRED / BLUE (+)AT HEADLIGHT SWITCH
Power LockWHITE/ GREENDRIVER KICK
Power UnlockYELLOW /GREENPANEL
* With OEM Alarm - Trunk Pin Switch Wire Can Be Found As BLACK/ RED (-) At OEM Alarm Module In Passenger Kick Panel.
Positive Pulse Door Locks
Accessories
Window UpD\ WHITE P\ YEL/VIO D\ YEL/BLU P\ YELLOW @ MAIN SWITCH
Window DownF/ YELLOW F/ WHT/VIO R/ WHT/BLU R/ WHITE
Ign Key Warn
Trunk ReleaseN/A
OEM HornBLACK/ BLUE (-)STEERING COLUMN HARNESS
HeadlightsORANGE / YELLOW (+)AT HEADLIGHT SWITCH
OEM Alarm ArmWHITE/ VIOLET (-)DRIVER KICK PANEL
OEM Alarm DisarmYELLOW/VIOLET (-)DRIVER KICK PANEL
Reversal Rest At Ground Power Window Circuit
Remote Start
Tach SignalWHITE/ BLACKAT POWERTRAIN CONTROL MODULE *
Ignition #2N/A
Ignition #3N/A
AccessoryYELLOWIGNITION SWITCH HARNESS
Neutral SafetyNOT GROUNDING TYPE -OEM SWITCH OPENS STARTER CIRCUIT
Brake LightORANGE / BLACK (+)AT SWITCH ABOVE BRAKE PEDAL
Reverse LightVIOLET/BLACK (+)14 PIN CONNECTOR BEHIND DRIVER DASH
Rear Window Defrost
* Powertrain Control Module Is Located On Passenger Rear Of Engine On Passenger Strut Tower.
FORD P.A.T.S. . ( Not All Of This Type Vehicle Will Have The P.A.T.S. System.
MO
