Avital 4400 remote start / alarm
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=63099
Printed Date: March 13, 2026 at 7:31 PM
Topic: Avital 4400 remote start / alarm
Posted By: billmullins
Subject: Avital 4400 remote start / alarm
Date Posted: September 22, 2005 at 5:58 PM
hi i picked up an avital 4400 remote start alarm from my friend. i have a install guide that i found online.... i just cant figure this thing out. its being installed in a 93 saturn. the only wires i have to conect to get the remote start to work are the brake wire... the acc, ign, ground , 12 constant, and the starter.. right.??? i understand the whole "satalite relay thing" but cant get it to work... the motor cranks but the ign and acc wires never become positivaly charged any help much appreaciated
Posted By: mo12v
Date Posted: September 22, 2005 at 6:11 PM
93 Saturn ..what??? Not sure on 4400 Some RS require programming or Neutral Safety Switch hook up, etc..........
------------- MO
Date Posted: September 22, 2005 at 6:17 PM
a sl. should the nutrual safty switch be +/- ??
Posted By: mo12v
Date Posted: September 22, 2005 at 6:44 PM
| Neutral Safety | NOT GROUNDING TYPE - | O.E.M. SWITCH OPENS STARTER CIRCUIT |
------------- MO
Date Posted: September 22, 2005 at 6:58 PM
the starter turns so i don't think its the nutrual safty switch... i could be wrong though... cant check till tommarow. if anyone has installed one of these before a rundown of what wires go ware would greatly help. mainly the 5 wire ribion to the relays for the remote start.. thanks
