PD-175 in 97 jimmy
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=63115
Printed Date: March 13, 2026 at 11:37 AM
Topic: PD-175 in 97 jimmy
Posted By: c**kroach152
Subject: PD-175 in 97 jimmy
Date Posted: September 22, 2005 at 9:40 PM
LOL i have read most of the forums related to this alarm system and im just trying to reference the info to my vehicle.  OK  my jimmy already has factory  keyless entry and back hatch keyless it has 4 doors and no panic button or anything i was just wondering if i need a bypass for it and were i could get one if i do.  One other thing i know the confusion about the oil senser and i have read that it is easier just to hook that wire to the alternater power wire or is it the alternater light wire behind the dash and if so what color is it. i think i have some factory wireing diagrams for my jimmy but if someone knows were i might find some different ones im always game.
laterz
Ryan
Posted By: genehewett
Date Posted: September 23, 2005 at 11:45 PM
   Lets start over. First tell us what you are tring to do. Is the pd-175 already installed? If so are you adding something to it? I tried to find a manual online to check on your oil sensor and alternator connections. I dont think you need to connect the system (even if it has remote-start) to the alternator or oil sending unit. I couldnt think of a reason to use the oil sender. The possible use of the alternator would be voltage sense for a remote-start and would be connected to the charge terminal (not recomended). Allways use tach sense when possible.
Date Posted: October 15, 2005 at 12:40 PM
this is a new install of the pd-175. it does not have a remote start on it but it does have the factory keyless entry my main question is do i need something to over ride or jumper the factory keyless entry or what. the other question is a good wiring diagram for the 97 jimmy 4dr . i did find one along time ago but not sure.
laterz
Ryan
Posted By: mo12v
Date Posted: October 15, 2005 at 3:48 PM
If this is the S-15 JIMMY:
Pretty straight forward Install............No Factory Alarm
After Installing the Alarm, just put your Factory Remotes in Glove Box & don't use
Constant 12 voltsRED & REDIGNITION SWITCH HARNESS
Ignition 12 voltsPINKIGNITION SWITCH HARNESS
StarterYELLOWIGNITION SWITCH HARNESS
Dome LightWHITE (-)AT PIN SWITCH OR COURTESY LIGHT
Trunk Pin SwitchWHITE (-)AT REAR PIN SWITCH (W/O KEYLESS) **
Parking LampBROWN (+)AT HEADLIGHT SWITCH *
Power LockL BLUEDRIVER KICK
Power UnlockWHITEPANEL
* BROWN (+) Wire Also Located In 23 Pin Connector Behind Driver Dash To Left Of Parking Brake. ** With OEM Keyless- WHITE/ BLACK (-) At Rear Pin Switch.
Positive Pulse Door Locks
Accessories
Window UpD\ D BLUE P\ L BLUE D\ D GREEN P\ L GREEN @ MAIN SWITCH
Window DownF/ BROWN F/ TAN R/ PURPLE R/ PURPLE
Ign Key WarnL GREEN (-)IGNITION SWITCH HARNESS *
Trunk ReleaseBLACK/ WHITE (+)AT RELEASE SWITCH
OEM HornBLACK (-)STEERING COLUMN HARNESS
HeadlightsYELLOW (+)AT HEADLIGHT SWITCH
OEM Alarm ArmN/ANO OEM ALARM PRESENT IN SCHEMATICS
OEM Alarm DisarmN/ANO OEM ALARM PRESENT IN SCHEMATICS
Reversal Rest At Ground Power Window Circuit Diagram. * L GREEN Wire Is Grounded Only When Key Is In Ignition Switch And Driver Door Is Open.
Positive Pulse Trunk Release
Remote Start
Tach Signal
Ignition #2PINK/WHITEIGNITION SW. HARNESS (TRANSMISSION) *
Ignition #3ORANGEIGNITION SWITCH HARNES (HEAT/AC)
AccessoryBROWNIGNITION SWITCH HARNESS
Neutral SafetyNOT GROUNDING TYPE -OEM SWITCH OPENS STARTER CIRCUIT
Brake LightWHITE (+)AT SWITCH ABOVE BRAKE PEDAL
Reverse Light
Rear Window DefrostN/ATIMER BUILT INTO SWITCH
* PINK/WHITE Wire Changes To WHITE At Base Of Steering Column. TAN/WHITE (-) Wire In Ignition Switch Harness Must Receive A Negative Pulse When Starting Vehicle For Daytime Running Lights To Operate Properly.
MO
Date Posted: October 15, 2005 at 7:18 PM
its the SLT but thanks for the chart
laterz
Ryan
