98 sebring remote start
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=63272
Printed Date: March 10, 2026 at 9:41 PM
Topic: 98 sebring remote start
Posted By: Reeceddogg
Subject: 98 sebring remote start
Date Posted: September 25, 2005 at 8:49 PM
Does a 1998 sebring coupe need a bypass
Posted By: mo12v
Date Posted: September 25, 2005 at 9:43 PM
NO..............
https://www.directechs.com/directwire/wire_body.asp?action=select&yr=2436&product=Remote%20Start
MO
Posted By: Velocity Motors
Date Posted: September 26, 2005 at 7:37 AM
If it has the GRAY Sentry key then it does. Depending on the month of the manufacture date, theSebring may or may not have an Immobilizer on the system. If you have a BLACK key, then no bypass module is required.
Date Posted: September 26, 2005 at 10:19 AM
It does have a gray entry key, will the 556u work and if so how do i program a new key, they don't have an owners manual
Posted By: gus1
Date Posted: September 26, 2005 at 11:56 AM
You need 2 keys to program any others. Instead of using 556U, use 555C.
To program:
1) 1st key to on (don't start the car) until the theft light goes out
2) 2nd key on, theft light goes out.... keep key on, theft light will come back on flashing, and car will ding once.
3)Remote start with pellet or ring in place... using a wait to start wire to make the unit power up everything without cranking..... it will take 20-30 seconds to learn the new key code.
These instructions also come with the 555c (dedicated Chrysler bypass)
Gus
